emco pc turn 55 conversion to mach3
  • #15209
    geoff adams
      @geoffadams14047
      geoff adams
        @geoffadams14047
        any of you guys help i want convert this cnc lathe to mach3 or something similar
        i know nothing about electronics the cad cam is driving me mad i can programme quicker by hand
        could you recommend a firm or someone that can do this for me iam in the Bournemouth area
        Thanks Geoff
        #394510
        John Haine
          @johnhaine32865
          These people seem to do CNC conversions, though up in Leicestershire.
          Why Mach 3? It's old fashioned and no longer supported. I have used it for quite a while on my lathe but will need to change soon. Compatibility with PCs and Windows depends on the goodwill of what is probably a dwindling user base finding fixes.
          Alternatives are LinuxnCNC, Mach 4, or a number of others have been mentioned here, but it may depend on how much of the current machine you want to keep.
          #394518
          geoff adams
            @geoffadams14047
            thanks for the link looks good will ring them tomorrow
            only reason for mach3 is my two mills syili x4 and tormach 1100 run on mach3 which i know i also have a sieg lathe with a fanuc based control
            thanks Geoff
            #394525
            Another JohnS
              @anotherjohns
              Geoff;
              1) There's a fellow who posts here sometimes (can't remember his name at the moment) who had figured out how to drive a parallel-port equipped Emco CNC lathe from LinuxCNC. He and his father got a batch of them.
              2) A local club member took his Emco Compact-5 CNC lathe and LinuxCNC'd it, including tool changer. Works very well, when he gets the chance to use it. (young family syndrome)
              3) If you have a Tormach 1100, you'll know that the PathPilot upgrade (*) is LinuxCNC with a Tormach UI and conversational programming layer.
              (I put a star on "upgrade" as I know we all have our own preferences, and some people have difficulty with anything other than Windows on a computer). Tormach dropped Mach in favour of LinuxCNC for a reason.
              4) I CNC-converted a Unimat SL lathe, which I gave to a club member, and have recently picked up a Sherline lathe, CNC controller is my old LinuxCNC one from my Unimat-SL. Sherline's CNC controller is LinuxCNC, so that's another company who chose LinuxCNC for their products.
              I'm a LinuxCNC advocate, as, not only is the price right, it just works 100% of the time for me, on 3 machines. I have converted to the "GMOCAPY" UI, which I like more than the standard UI.
              Again, there's lots of choice out there; every solution has good points and bad points.
              #394526
              geoff adams
                @geoffadams14047
                John some photos of the machine had it for about ayear never used it the cad cam is a nightmare get fed up and use my other machine the fellow i got form got it as an ex demo dont thick it has ever cut anything want to kep as much of the machine as possible as it all looks as new
                Geoff
                #394559
                The Novice Engineer
                  @thenoviceengineer
                  Hi,
                  I've converted an Emco Turn 50 to run of Mach3 a while back, ripped out all the Emco controls but kept the original Main Drive motor and stepper motor's.
                  I used a Generic Chinese [E-bay] parallel port interface controller card, Vertex 5 phase stepper drives, and a Omron VFD .
                  It was mostly re-wiring rather than building new electronics.
                  I run off a Windows XP pc the Operating System has been stripped down to the essentials and NEVER connect it to a network or the Internet. [Mach 3 control via the Parallel Port only works under XP or 2000. Windows 7 and above should use a USB interface card]
                  The Main drive is under manual control as is the Tool changer, Mach 3 looks after the X and Z axis.
                  So far this has done every thing I have asked of it, including taper turning, threading …. the awkward stuff …etc.!!!
                  I use Fusion 360 for the CAD – CAM, and the Mach3 Wizards for simple stuff.
                  Steve
                  #398289
                  The Novice Engineer
                    @thenoviceengineer
                    Here are some photos of my Emco PC Turn 50 cabinet with the rewired power side , the Rack mounted PC and 5 axis controller, the Drive motor VFD and the Vertex 5 Phase stepper drivers.
                    I had been using this as test bed for trying out ideas before modifying a Emco PC 50 Mill, The lathe retains the original  Emco 5 phase stepper drive motors and the 3 phase main drive.
                    img_20190225_124846.jpgThe transformer was retained to provide 24v for the tool changer. The Vertex drives are 110v and are run form tapping on the primary side of the transformer.
                    The Power supply at the front is for powering the PC [a Mini ITX dual core running XP off an SSD ..very quick] it also powers the Mach 3 control card, and recently the Tachometer RPM meter
                    The terminal block is a power take off for testing the RPM Tachometer of the Main drive.
                    Steve
                    Edited By The Novice Engineer on 28/02/2019 22:13:56
                    Edited By The Novice Engineer on 28/02/2019 22:18:50
                    #398376
                    The Novice Engineer
                      @thenoviceengineer
                      Update:
                      A bit of a senior moment dyslexia with the spelling of the drives I used!
                      The 5 phase drivers are by VEXTA , to use these the Emco Berger-Lahr stepper motors have to be re-wired internally about a 5 minute job changing links around. The Vexta pentagon drivers have five output terminals; each one connects to two motor cable conductors
                      I've added the information about how I did my modification to this thread as the title may draw folk in who are looking to do a modification.
                      Steve
                      Edited By The Novice Engineer on 01/03/2019 21:00:18
                      #398429
                      wendy jackson
                        @wendyjackson
                        Mach3 is just running software, what makes or breaks the system is the breakout board. after years of fulling around with cheap rubbish from china and old PC,s running with printer ports I went for the CS=LABS CSMIO motion control unit which uses the lang port. great bit of kit and works right out of the box. I use the units on my large router and a Denford engraving machine I converted. all work with mach3 and windows 10. mach4 is too full of bugs at the moment, so happy with the software I have.michael
                        #402066
                        Andreas Chronz
                          @andreaschronz93321
                          Hello!
                          I`am Andy from Germany and a friend of me bought a PC Turn 55 too. But he had also Problems with the original Fanuc Control and want to Keep them out and replace it with another control (i`am looking for Mach3 too).
                          Anybody knows which mainspindle Motor the machine has? (Didnt find a Information sign on it). And how epensive are These vexta Drivers?
                          Kind regards
                          Andy
                          #402075
                          John Haine
                            @johnhaine32865
                            I use Mach 3 on my self-converted Super 7 and Denford Novamill and have been doing so for some years with success. I've got quite a lot invested in it in terms of macros for tool setting and modified screen sets.
                            BUT, if you are looking at converting a machine NOW, why would you want to use a controller like Mach 3 which is no longer supported by its supplier and you are dependent on fixes developed by the use community, for example to cope with problems created by upgrades to Windows? That user community will itself decline as they move to modern supported systems.
                            It must be better to use Mach 4 or a different controller such as LinuxCNC or UCCNC.
                            #402076
                            David Colwill
                              @davidcolwill19261
                              I run Mach 3 on 2 milling machines and a Denford Easiturn lathe. They all work fine for what I do but I am still thinking of going to the dark side (linux) and have bought a Denford Orac as a test bed machine. If I get on with it I will probably switch over on everything.
                              The main reason is threading. While the easiturn is big enough to manage this on short threads it loses sync over 40mm or so. This is going to be much more of a problem on a smaller lathe like the PC Turn.
                              I have always meant to try linux but have never got round to it so now hopefully I soon will.
                              Regards.
                              David.
                              #402077
                              David Colwill
                                @davidcolwill19261
                                Posted by John Haine on 25/03/2019 10:16:34:
                                I wish UCCNC would go more lathe friendly I use a UC300 at the moment on the lathe running mach 3.
                                I have emailed them several times regarding spindle sync (it works on the mill version for tapping) but they always reply that there is no interest in lathes etc. I haven't tried the software though.
                                Regards.
                                David
                                #402078
                                Another JohnS
                                  @anotherjohns
                                  David beat me to it – threading.
                                  LinuxCNC works well, and blows Mach3 out of the water, from what I hear.
                                  The reason seems to be that LinuxCNC uses two spindle sensors – one to mark 0.00 degrees, and the other divides the spindle rotation by "lots". Mach3 only has the 0.00 degrees and interpolates the spindle rotation from that.
                                  I use "Mesa" boards, which seem to be inexpensive compared to Mach hardware. The whole stuff just works.
                                  Note: John Stevenson (miss that guy) and I used to "argue" – he liked Mach3, I like LinuxCNC, so my comments above regarding Mach3 are from discussions with Mr. Stevenson, not my personal experience.
                                  #402079
                                  Emgee
                                    @emgee
                                    Posted by David Colwill on 25/03/2019 10:17:00:
                                    Regards.
                                    David.
                                    Please keep us posted on any upgrade, I am still using an Orac with OEM controls.
                                    Emgee
                                    #402083
                                    blowlamp
                                      @blowlamp
                                      If you want true spindle-synchronised lathe threading, there are three reasonably priced options that I know of.
                                      1/ LinuxCNC.
                                      2/ Centroid Atom.
                                      3/ PlanetCNC TNG.
                                      Martin.
                                      #465927
                                      Elmouatez Billeh KEBIR
                                        @elmouatezbillehkebir26266
                                        Hello.
                                        can i find someone who can give me the characteristics of the tool changer motor on the emco pc turn 55.
                                        thank you
                                        #466197
                                        The Novice Engineer
                                          @thenoviceengineer
                                          The Tool change motor is 24v DC,
                                          The small control board for it will apply 12v to reverse the motor to locate the toolholder in position against a pawl/ratchet,
                                          The 12v is maintained continuously to hold the tool in position. The motor housing has a large heat sink it does get warm but not hot.
                                          Trust this helps
                                          Steve
                                          #466254
                                          Martin Connelly
                                            @martinconnelly55370
                                            David, Mach3 threading works fine on the right lathe. What it needs, because of the one pulse per rev synch, is a lathe with plenty of rotating mass and a powerful motor to give unvarying speed as the cutting progresses. Basically it will be more problematic on a dc motored mini lathe than a machine with a big 3 phase motor and a transmission, spindle and chuck that probably weighs as much as a mini lathe. You need the same rpm as the cut is ending as before cutting starts, and this needs to be true every pass.
                                            Martin C
                                            #548008
                                            Joseph Noci 1
                                              @josephnoci1
                                              Posted by Emgee on 25/03/2019 10:32:02:
                                              Regards.
                                              David.
                                              Emgee
                                              What type of motors drive the X/Z axis on the Orac? What is the spindle motor?
                                              I would be happy to help you get the lathe onto Linuxcnc , to the extent that I can! My homebrew CNC lathe was reasonably easy to get working as a simple 2 axis lathe – but had a hernia getting the C axis function implemented. If you are not doing that sort of thing, the system configurator tools in LCNC get you very close to a working machine.
                                              The issues lie in the axis motors, etc – if X/Z are plain steppers, you could configure it yourself. If closed loop steppers or servo's, notwithstanding all those linuxcnc experts who claim Linuxcnc is the answer to all questions – you will endure pain! And if the spindle motor is a big closed loop servo, the pain is exquisite…However, similar pain lies ahead for such implementations even with the likes of PlanetCNC, Centroid, etc…unless for the latter you buy a 'configured' kit with motors, etc..= money..
                                              Joe
                                              #548012
                                              Emgee
                                                @emgee
                                                Posted by Joseph Noci 1 on 01/06/2021 14:47:49:
                                                Regards.
                                                David.
                                                Emgee
                                                Joe
                                                Joe
                                                The XZ axis are driven by Stepper motors and the spindle drive is 3 phase controlled by a VFD, speed is programmable within the program, power required is 220-240v AC single phase.
                                                Emgee
                                                Edited By Emgee on 01/06/2021 16:37:50
