spiral spindle cutter
Viewing 25 posts - 1 through 25 (of 66 total)
  • #15186
    john constable
      @johnconstable10725
      john constable
        @johnconstable10725
        High everyone! New member, first post and first project!
        I want to cut spirals on spindles (aka barley twists) in wood and it looks like its going to need a custom tool.
        It's basically as 'simple' as replacing a lathe tool with a router and getting the work to rotate slowly in sync with the tool moving along the bed and not at a cutting speed. Hope that makes sense.
        All of this is just for miniature work on spindles up to 1.5" thick and up to 6" long so a full sized lathe is overkill.
        A metal work lathe that can cut threads will sync rotation and tool travel but I can't see how you would get the work to rotate slowly enough, the pitches seem to be too small and from what I can see see I couldn't justify such a large cost. A smaller one would be cheaper but would it cut threads and support a dremel?
        Having set metalworking lathes to one side, I looked at woodworking lathes. On full sized older and cheaper lathes you can disconnect the belt drive and turn the work by hand but you can't sysnc tool movement to rotation. Smaller lathes have a direct drive motor which wont turn slowly with any kind of torque but there's still no easy way of syncing them.
        My current plan is to bolt a milling table onto a drill stand with a dremel in it and fabricate a headstock and tailstock to hold the work. Then I can turn the headstock (large chuck?) by hand and link the rotation of the headstock using a sprocket and chain arrangement to the bed advancing wheel to move the work under the tool.
        So, I'm really looking for ideas – alternative ideas that might fit my skills and budget to achieve my desired result or just where to get suitable sprocketage and chainage from.
        A couple of other thoughts – the pitch of the spiral is in the order of 1:1 (that's the diameter of the spindle in tool movement versus number of rotations) but of course I really need to vary that slightly to increase and decrease the spiral pitch. And I looked at a stepper motor solution but its an area i'm unfamiliar with and I know its going to involve controllers, iterfaces, pcs and software etc so I dont think it would be an easy or inexpensive path for me .
        Any advice offered gratefully received!
        #358352
          Have a search for "legacy ornamental mill" or the old Trend router lathe to see how with some pulleys and cables the spindle is linked to the tool movement
          #358355
            Predictably enough, Jason beat me to it
            I think the Trend RouterLathe uses the operating principle that you need, John
            Here, with a ridiculously long URL, is the Instruction Manual: **LINK**
            Edited By Michael Gilligan on 18/06/2018 20:10:27
            #358356
            john constable
              @johnconstable10725
              Believe it or not I had a TRL but it got lost in a house move before I had the chance to use it and I never had the opportunity to replace it.
              If dremel made one that would be great but that arrangement of strings and pullys looks harder for me to achieve than using a couple of cogs and a chain – especially on the scale I need to work at.
              #358357
              larry phelan 1
                @larryphelan1
                Hi John,
                I have an old Trend catalog buried deep [not seen it for years],in which the is a machine,using a router to do just that kind of work. The router is arranged to move along the workpiece while the work revolves. The speed of the advance is dictated by a wheel,turned by hand.
                Might be worth checking out Trend
                #358358
                  Posted by john constable on 18/06/2018 19:15:48:
                  Due to the gearing you will find it easier to move the tool (mill table handwheel) and have that drive the chuck. This is how very coarse threads can be cut with a screwcutting lathe, the leadscrew is turned by hand and that is geared to slowly turn the spindle. So small gearwheel on the mill table and a big one on the spindle to get the pitch you require.
                  Edited By JasonB on 18/06/2018 20:40:53
                  #358359
                  john constable
                    @johnconstable10725
                    I think I see what you mean. So it's basically what I was proposing but instead of turning the chuck by hand I'd turn the table advance knob by hand? Either way the tool would still be static in the drill stand.
                    Would some kind of flexible shaft be a mad idea? Too much play?
                    #358360
                    john constable
                      @johnconstable10725
                      Posted by larry phelan 1 on 18/06/2018 20:34:20:
                      Hi John,
                      That's the trend router lathe that the guys have pointed me towards. Its quite a complex arrangement of runners, pulleys and strings. I think it would be hard to make one from the few pics available but I dont think it would be suitable in a smaller form for the size of work i need.
                      #358368
                        John,
                        I've just been browsing around, and found this page: **LINK**
                        https://stusshed.com/tag/beall/
                        The first couple of pictures are another [perhaps the original?] routerlathe-style device … but then it gets more interesting: Maybe sufficient to get your inventive streak going.
                        Edit: Here is Beall's website:
                        http://www.bealltool.com/products/penwizard/penwiz.php
                        Where you will find detailed instructions and some excellent photographs angel
                        Edited By Michael Gilligan on 18/06/2018 21:41:20
                        #358379
                        john constable
                          @johnconstable10725
                          Posted by Michael Gilligan on 18/06/2018 21:33:03:
                          John,
                          Fantastic! You star! A bit worried it'll only do pen-barrel size stock but maybe I can stretch it. Holding stock will need some though because pen barrel blanks are hollow and held in a mandrel.
                          Not cheap but it looks worth the money and probably cheaper than building my own from scratch.
                          Thanks, Michael.
                          #358380
                          john constable
                            @johnconstable10725
                            thought I'd post these for your interest.
                            Ive listed them in reverse so you can see the results first then how he built it.
                            I wonder if you can get tiny bikes complete with gears?
                            #358391
                              This is how it can be done on a mill which is what your drill and milling table will effectively be.
                              The large handwheel has gears just inside it which are driving the feed screw on the mill table and then the work is being rotated via a dividing head.
                              You would just need a simple setup between the handle and spindle, say you wanted a 3" pitch to your spiral and one turn of the table handwheel moved it 0.100" then a 30:1 ratio would give you 30 turns of the handwheel (30×0.1=3 ) to 1 turn of the spindle. As the leadscrew and spindle axis will be parallel it should not be so hard to set up.
                              #358397
                              Martin Kyte
                                @martinkyte99762
                                If you are going to do it on the lathe you need to drive the lead screw. If you have a hand wheel on the lead screw just wind that and let it drive the chuck.
                                regards Martin
                                #358399
                                Anonymous
                                  Posted by JasonB on 19/06/2018 07:33:18:
                                  Seems a slightly odd way to do it as he seems to be driving the dividing head through the worm reduction. It would be simpler to drive the table leadscrew directly and have a reduction gear direct to the dividing head spindle.
                                  #358416
                                    He does seem to be doing some sort of dividing as well as he can be seen turning the div head handle a number of turns while the mill table is not being moved. Have a look about 2mins into the video. Possibly getting the correct tooth profile by using co-ordinates consisting of Z-height and an angle either side of his starting point.
                                    A rotary table may have been easier for just a helix as the end of the R/T spindle is accessable and could easily be extended to take a gear/pulley that lines up with the mill table handwheel.
                                    Edited By JasonB on 19/06/2018 10:31:08
                                    Edited By JasonB on 19/06/2018 10:31:37
                                    #358424
                                    Anonymous
                                      Posted by JasonB on 19/06/2018 10:10:23:
                                      Indeed, not sure why, although you may well be right? It doesn't look like a multistart worm. Got to be easier using CNC. smile
                                      #358438
                                      john constable
                                        @johnconstable10725
                                        Wow… I wish I understood what you are all saying!
                                        What I do pick up from it is that what I need is model/hobby sized helical milling machine?
                                        I suspect they dont make them…. so how do I create one? Can a mini metalworking lathe be modified? In my original post I outlined how I thought I might go about making one from scratch. I just need a way to link the hand-turned chuck with the milling table wheel in such a way I can control the spiral pitch. A simple gearbox I suppose or an arrangement of cogs and chain like you'd have on an old lathe to control speed. That much eludes me.
                                        So frustrating a metalworking lathe just can't quite do it!
                                        #358442
                                          It can be done on the mini lathe.
                                          -Make a bracket to hold Dremel or router on the cross slide where the cutting tool would normally go.
                                          – Make something to hold a large gear/pulley etc on the far end of the main spindle
                                          – Make or possibly use the existing gear position on the end of the lead screw to hold the smaller pinion that will drive the large spindle gear. The leadscrew is the long screw that runs along the front of the lathe.
                                          – Make a handle to turn the leadscrew with, this could just be a ply or MDF arm with a knob to get hold of.
                                          – Set the Dremel running, use the cross slide to move it into the work and then turn your leadscrew handle which will make the Dremel move along the work as it slowly rotates.
                                          EDIT this guy did a 1 turn per inch spiral using the supplied gears by setting them in teh right order, may be possible to get a steeper spiral that way.
                                          Edited By JasonB on 19/06/2018 13:37:16
                                          #358444
                                          Keith Long
                                            @keithlong89920
                                            As Jason says above, it can be done on a lathe – easier than messing around with a mill and dividing head etc.
                                            Assuming that you haven't got a lathe or milling table etc yet, keep a look out for an old simple lathe that has screw cutting abilities, ie one where you can gear the lead screw to the main spindle. For your usage you probably won't be too worried about the state of the bearings on the main spindle – so long as the spindle isn't flopping around everywhere, you won't need the sort of rigidity and precision that metal turning would. The issue to solve then is getting the gear train to connect the lead screw to the main spindle and here you needn't stick to the "correct" gears so long as you can construct a working gear train. Gears can be bought from EBay as well as dealers, but for your usage gears from the like of Technobots would also be suitable.
                                            If you haven't got access to metal working machinery (a lathe) for making the odd bits that you'll need, give us a clue to whereabouts in the country you are, the chances are that there wi8ll be someone near to you who would the able and willing to help you.
                                            #358446
                                            john constable
                                              @johnconstable10725
                                              I'm doing my best to picture that. I'm ok with mounting the dremel to the crossslide somehow.
                                              The lead screw is the long threaded rod that is motor-driven to move the carriage along the length of the lathe. Presumably it can be disconnected from the drive and you are proposing I turn it by adding a knob on the end? If its what I think it is, dont most lathes have a wheel for manually turning the lead screw already?
                                              #358447
                                              Alan Johnson 7
                                                @alanjohnson7
                                                From memory, part of the Quorn Tool & Cutter Grinder construction notes there are instructions on how to mill a groove (rapid thread) in the column – using a Myford ML7 and some sort of auxillary drive to the mill cutter mounted on the topslde, but that is all I can remember. Anyone with a better memory or the construction notes may be able to help.
                                                #358449
                                                john constable
                                                  @johnconstable10725
                                                  Posted by Keith Long on 19/06/2018 13:42:50:
                                                  Thanks, Keith… I feel I’m getting closer all the time.
                                                  I think which ever method I’ve looked at it’s the issue of driving the lead screw from the spindle that is the trickiest part. At it’s simplest I imagine a cog on the spindle and a cog on the lead screw in line with it and a chain joining the two?
                                                  Assuming I can choose cogs that give me the right speed ratio for a barley twist pitch, how do I vary it to vary the spiral pitches or would I just be stuck with one?
                                                  If thread cutting lathes had a bigger range of ratios we might be in business!
                                                  #358453
                                                  john constable
                                                    @johnconstable10725
                                                    Posted by JasonB on 19/06/2018 13:32:20:
                                                    Thanks for that video. I think I see whats going on now. The problem this guy has ended up with is one I'm grappling with. How do you vary the gear ratio for different pitches? At least he's managed a low enough pitch to get one working. I didn't think that was possible on a small hobby lathe.
                                                    #358454
                                                      You would just change the gear ration between the lead screw and the spindle to get a fast or slow helix
