John,
1). Open to other suggestions such as Ethernet – but I am trying to get away from printer boards which are ever more difficult to locate and built to ever lower quality levels. One of the chief issues I have with the PoKeys is that there is obviously some disconnect between the board and the PC since starting it seems to be vaguely random but associated with moving the joystick and also there is s serious lag between inputs to the board and activity at the pc – or rather ibn-activity since movement continues long after stopping the input.
Whether this is Mach3 or Pokeys or a combination of the two – I don't care, but it is seriously not right to a dangeroyus degree…
2). Yes, I was aware they work with LinuxCNC but I have a paid up Mach3 licence and extra coding and effort focused on Mach3 as well as having my mill completely driven by Mach3. I was hoping someone could report on their use with Mach 3…..
3). Thanks – I may have to go down this route.
4); Good luck – I still have my Unimat3 which I was given when I was 18, although it constantly trips the ECB now and needs 'investigation'
Simon
