Mach 3 Training
Mach 3 Training
  • #99778
    John Stevenson 1
      @johnstevenson1
      Spun this post off from the original mach 3 thread so it's back on topic.
      We, small son and myself run a web based support site for the Sieg CNC machines.
      This is a two tier site, some of the site anyone can see, some is only for registered users.
      Would there be any demand for a sub forum for new users to Mach3, sorry can't do Linux, not enough experiance, ?
      We have plenty of server space so that's not a problem and can handle any size of files
      I do not class myself as an expert but do have a long associationship with Mach 2 and later Mach 3 when Art was in charge.
      John S.
      John Stevenson 1
        @johnstevenson1
        #99781
        GoCreate
          @gocreate
          Hi John
          I find the Art Software forum helpful but when searching and reading posts generally a bit over my head and time consuming to find that answer your looking for.
          As a new user for cnc milling I would certainly be interested in a forum dedicated to entry level mach3 and G code for both mill and lathe.
          Also of interest at entry level are:-
          1. Economical 3D milling regarding Cad and Cam.
          2. Digitising
          Cheers
          Nigel
          #99782
            John,
            That sounds an excellent idea.
            Rod Ashton
              @rodashton53132
              "Maidens prayer" Can we have a link?
              I for one, would be pleased to contribute my 2&3D CAD knowledge if desired.
              #99789
              John Stevenson 1
                @johnstevenson1
                The site link is http://www.smallcncsupport.com
                As I stated this is the Sieg support site and the members part is not visable but in all fairness there isn't a lot on there. Most problems we have are setup problems and once they have been sorted everyone seems to get on OK.I'll get small son who does all the site work on here nad the free advert site to sort a sub forum out and repost the direct link later when it's set up.
                #99790
                John McNamara
                  @johnmcnamara74883
                  Hi John
                  Great work…..
                  Cheers
                  Rod Ashton
                    @rodashton53132
                    Took a look! – I have an old ArcEu conversion. It seems the registration is only for newer machine users? i.e Dealer info etc. requirement.
                    #99798
                    John Stevenson 1
                      @johnstevenson1
                      Rod,
                      The support site is for Sieg machines only, and technically for one year although it's never enforced.
                      The site was never runing when the conversion machines were done.
                      #99806
                      Rod Ashton
                        @rodashton53132
                        I see on another thread that you run CNC courses. Would you PM some details and location info. please.
                        #99829
                        John Stevenson 1
                          @johnstevenson1
                          OK guys site up and running.
                          http://training.smallcncsupport.co.uk/
                          Four categories, General, CAD/CAM, Milling and Turning, think that we do as I hate 1,000's of groups and sub groups.
                          Typical forum startup, you have to register and the first posts do no appear straight away as they are moderated against spam, after that it's a free for all.
                          Nothing on there at the moment but if you want to post please do so, in fact an introduction will get you past moderation. We will start adding content tomorrow but hopefully the site will be used for all and not small son's and my blog.
                          Feedback will be willingly accepted.
                          John S.
                          #99892
                          Sub Mandrel
                            @submandrel
                            John,
                            I'm assuming you know the X2 as well as the X1 and X3. I've had the head casting apart in two pieces and there is no positive location to realign them. For those who wonder what I'm on about the X2 head is in two parts one with dovetails, the other with the spindle held together by four M8 bolts, but no key or even two adjacent, level surfaces as a guide for alignment.
                            The sides of at leas the front casting are not parallel, presumably the dovetails and spindle are aligned with reference faces. I'm guessing these are either the tops or bottoms of the castings so I've gone with shimming the back up on a surface plate while the front rests on the plate..
                            Do you have a better way for realigning these castings?
                            John Stevenson 1
                              @johnstevenson1
                              Neil,
                              Not all that familar with the X2.
                              I do have one but it's the prototype one that ARC sells with the fixed column and the brushless head, what's know as the Super X2.
                              This has a different head to the basic X2 and the head on these is a one piece casting, sorry.
                              #102975
                              Russell Eberhardt
                                @russelleberhardt48058
                                Posted by Stub Mandrel on 02/10/2012 20:09:46:
                                Neil,
                                Only just seen your post as I've been away.
                                This is how I aligned the head on mine: **LINK**
                                Russell.
                                #102977
                                Russell Eberhardt
                                  Posted by John Stevenson on 01/10/2012 22:13:51:
                                  Sounds as if it could be a very useful site for me as I have completed my SX2 conversion and now need to learn how to use it!
                                  Only problem is that the link doesn't work for me.
                                  Russell.
                                  #102982
                                  GoCreate
                                    @gocreate
                                    Hi John/Russell
                                    The link has also stopped working for me, I get a 'Forbidden' message.
                                    It was fine a few days ago.
                                    Nigel
                                    #103140
                                      John S.
                                      John,
                                      For info; the site still seems to be unavailable.
                                      … have you changed the address ?
                                      Another JohnS
                                        @anotherjohns
                                        Maybe John Stevenson has decided to join the LinuxCNC movement?
                                        Ducking, to avoid thrown projectiles…
                                        (He's probably out there making money, like most of us pre-retirees have to do)
                                        Another JohnS.
