Harrison L5
Harrison L5
Home Forums Manual machine tools Harrison L5
  • #658421
    Derek cottiss
      @derekcottiss41883
      I have an L5 with the norton gearbox that i am resurecting from single to 3 phase and a general tidy up .
      i have 3 questions
      what was the original motor pulley size ?
      what is a good modern oil for the head ?
      and finally what changewheels are 'standard fit' to enable the gearbox to run as listed on the cover ?
      thank you ..
      Derek cottiss
        @derekcottiss41883
        #658450
        DC31k
          @dc31k
          Harrison L5 manual here (one at the top of the page, one at the bottom):
          http://vintagemachinery.org/mfgindex/detail.aspx?id=3031&tab=3
          I am reasonably sure it is not what you want, but am including it just in case. It is the screwcutting chart for the 'basic' L5 model:
          https://www.ebay.co.uk/itm/364215982969
          #658451
          Chris Crew
            @chriscrew66644
            I use a generic H32 oil from the local oil and grease merchant in a Colchester Student.
            #658544
            Derek cottiss
              @derekcottiss41883
              Posted by DC31k on 30/08/2023 07:58:59:
              the bit im finding confusing is the change wheels .it has an imperial norton box but does changing the change wheels alter the tpi on the box ?
              #658547
              DC31k
                @dc31k
                Posted by Derek cottiss on 30/08/2023 19:23:00:
                Of course it does. You can prove it to yourself. Hold a piece of broomstick in the chuck and use a marker pen in the toolpost to draw the thread onto the wood. Alter the changewheels upstream of the gearbox and see what effect it has.
                Please advise which of the manuals you have and the page number that is relevant to your machine. Do the gears you have on the machine right now match what is there?
                #658556
                Derek cottiss
                  @derekcottiss41883
                  Posted by DC31k on 30/08/2023 19:39:24:
                  ok got it on page 12 i was too busy looking for it and missed the norton box reference . i was panicking as theres no change wheels present except those fitted and didnt know it they were standard .Currently only need the threads on the box ..
