Hi All,
I am wondering if anyone can give me a bit more information about the bearing of the horizontal cutter spindle is lubricated. The description I have is taken from Alexander Operating Instructions.
![spindle lubrication.jpg spindle lubrication.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
If I am reading them correctly, first you will the gear box with oil followed by the pockets around the spindle. It then seems that you never need to fill the pockets again, presumably they are topped up from the gear box. How does this work, is there some sort of pump system?
Also the manual states that the oil level in the pockets can be checked through a window on the front face of the head. You will see below that on my machine there is no such window! All other pictures I have seen of both the Alexander and the FP1 have this window. My machine was made in 1968 and the manual I have is the one that came with it. My machine was made in 1968, perhaps there was a design change around then. So how do I check the oil level in my machine?
Bob
![img_1189.jpg img_1189.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
