R8 Tooling for Warco Super Major Mill
Home Forums Manual machine tools R8 Tooling for Warco Super Major Mill
Viewing 25 posts - 1 through 25 (of 28 total)
  • #624436
    Martin Currie
      @martincurrie
      Hello Guys
      I've just recently bought myself a new Warco Super Major mill direct from Warco and I'm looking for some advice on buying an R8 keyless drill chuck and R8 collets to hold my end mills.
      APT in Glasgow is my main supplier for HSS/carbide milling cutters, I have noted that on their website they sell R8 drill chucks with TIR 0.05mm, I’d like people’s opinions on this, would this be classed as a low amount of runout for a drill chuck. My knowledge on this subject is a little bit limited, so any feedback would be appreciated.
      Also, I haven’t decided if I’m gong to use R8 5C collets to hold my end mills or use an ER32 R8 collet holder.
      What would be the most optimum setup for this mill? I like the idea of maximizing vertical space with the R8 collets instead of losing a few inches with the ER32 system. also what about runout on collets is there a particular brand that i should look to buy either ER32 collets/holder and the direct R8 collets?
      Thanks for your help.
      Martin
      Martin Currie
        @martincurrie
        #624443
          If enough head-space, I would likely opt for an ER collet chuck.
          #624451
          John Haine
            @johnhaine32865
            R8 collets every time. I bought a set from MSC when I got my VMB and they are excellent, grip like the proverbial, don't eat daylight. I've got 2 keyless chucks, one 13mm Vertex the other 6mm Albrecht, both on standard R8 to taper arbors. I haven't measured their runout but not noticed any issues.
            #624452
            john halfpenny
              @johnhalfpenny52803
              Adapters are not ideal but Morse into R8 goes satisfactorily, so you can use what Morse stuff you have. I have an ER32 collet chuck in R8 for my mill, but also use an MT2 Jacobs chuck with adapter sleeve for drilling. Obviously (for milling) you will need to check the drawbar thread is suitable for your chuck of choice, and if necessary make sure it goes through the adapter to engage the chuck directly.
              #624461
              John Hinkley
                @johnhinkley26699
                Martin,
                I use an ER25 or ER32 collet chuck in my Warco VMC mill. When daylight under the quill is in short supply, I use R8 collets directly in the spindle, but I don't suppose I've used them more than a handful of times in my ownership of the mill, about 7 years and even then I've think I've only used one or two out of the set. I'd go for an ER collet first and buy R8 collets as dictated by the particular job requirement. I have to admit that I work to tolerances way over the NASA requirement and ER25/32 works fine for me. Never checked for run out.
                jaCK Hobson
                  @jackhobson50760
                  Posted by Martin Currie 2 on 11/12/2022 07:11:41:
                  TIR 0.05mm,
                  That is much better than the runout I measure (5x) on any of my chucks when installed in the mill and measuring off a milling cutter shank.
                  I'm collecting R8 collets/arbours as I need em. Great (if you tighten them up ). Some need fettling to fit at first.
                  Maybe there is a time saving between R8 and ER to consider if changing a lot … I don't know which way though.
                  #624470
                    I only use the R8 or MT3 collets when the job means I run out of head room to use ER collets. The biggest downside I find with direct collets is being able to see what you are doing or getting in close when clamps or say the spin indexer are used when using small cutters. Here is an example of a 3mm cutter in the SX2.7 held in a 6mm R8 collet.
                    Can't get to my R8 mounted chuck at the moment but I get 0.05mm with my MT3 one from ARC, this is a commonly quoted figure from many of the top brands but like a 3-jaw lathe chuck a drill chuck is not as accurate as collets would be and you should be able to get 0.005mm with collets as I do without splashing out.
                    #624476
                    Ronald Morrison
                      @ronaldmorrison29248
                      A drill chuck is intended to hold drill bits….which are not high precision. Their purpose is to make a hole, not necessarily a round hole and not to an exact size. You don't want the drill bit to wobble about but a tiny bit of runout in the chuck isn't going to affect the making of a hole. If you want a more precise hole you use a center drilling end mill in a collet.
                      #624480
                      Tony Pratt 1
                        @tonypratt1
                        I use R8 collets all the time, I think I may have an ER collet system also but haven't used it as yet.
                        Tony
                        #624485
                        Martin Connelly
                          @martinconnelly55370
                          If you go for R8 collets then get yourself one that is Ø16 and you can then get an ER16 collet holder with a Ø16 parallel shank for when you need to get in close with cutters or drills up to Ø10. This uses up far less space than a drill chuck and can be fitted into the R8 at different heights to suit the work that is being done.
                          Martin C
                          #624491
                          Mick B1
                            @mickb1
                            Back in the 70s I worked a Bridgeport which had a small drillchuck with an R8 mount. I used to use it for co-ordinate drilling jobs amongst other things, and some of these had tight tolerances. Before I got to trust wobblers, I'd set it up against a datum edge with a .2500" dowel. My close-in eyesight was sharp then, and I think that on a good day that gave me a bit better then 0.002"/0,05mm TIR.
                            My guess is that APT are quoting the runout they (or their supplier) can guarantee, and most setups where careful practices are followed will give better.
                            Use collets where you can – the benefit of R8 collets isn't just space-saving, it's stiffening the resistance to any sidestress by shortening the leverage.
                            Edited By Mick B1 on 11/12/2022 11:54:55
                            #624528
                            John Haine
                              @johnhaine32865
                              R8 collets every time. I bought a set from MSC when I got my VMB and they are excellent, grip like the proverbial, don't eat daylight. I've got 2 keyless chucks, one 13mm Vertex the other 6mm Albrecht, both on standard R8 to taper arbors. I haven 't measured their runout but not noticed any issues.
                              #624534
                              old mart
                                @oldmart
                                We got a full set of R8 metric collets with the drill mill at the museum, and after several years, most of them are unused. They have little or no tolerance for missmatched diameters, I have had to buy 4 imperial ones. It would be best to only get the sizes which match the cutter shank diameters that you intend to use.
                                With an er collet system, either er25, (up to 16mm) or er32, (up to 20mm), it would be advantageous to have a set especially if you fancy using then on a lathe as well using a Morse Taper adaptor or a collet plate, as a set can cover every size if workpiece.
                                With sets of er collets, it would be better to get quality ones from Cutwel or APT, they specify the runout tolerance, I have a couple of Chinese sets which leave a lot to be desired in that respect.
                                Edited By old mart on 11/12/2022 14:36:04
                                #624753
                                Martin Currie
                                  @martincurrie
                                  Guys
                                  Thank you so much for all the feedback on the R8 collets and ER 32 system.
                                  I'm going to mix and match to get the best of both worlds as they say. I've ordered a set of ER32 collets and chuck from APT. I'll get a few R8 collets also.
                                  Thanks again guys
                                  Martin
                                  #624813
                                  Jelly
                                    @jelly
                                    Posted by Martin Currie 2 on 13/12/2022 06:46:34:
                                    Guys
                                    Thanks again guys
                                    Martin
                                    Best of both worlds!
                                    If you get a 12mm R8 collet then you also have the option of buying an ER11 or ER16 straight-shank chuck later (both sizes are available with a 12mm shank you see) to give you *even better* visibility when doing jobs requiring small milling cutters, the "chuck-on-a-bar" jobbies are about 15-25 quid should you find you do need that in the future.
                                    #624823
                                      If you are going down that route why not just get an R8 ER16 rather then risk combined runout of R8 collet and ER holder as well as the thinner straight shanks not being as rigid as an R8
                                      #624830
                                      Jelly
                                        @jelly
                                        Posted by JasonB on 13/12/2022 16:04:21:
                                        You can extend an ER11 straight shank somewhat lower than you can buy an R8 ER16 holder, giving the best visibility.
                                        Other than visibility there's no reason to go down to a smaller ER as you can get collets down to 2mm for ER32, so you might as well maximise the visibility you're getting in a trade off.
                                        Straight shank collet chucks are also cheaper and more easily available than R8 ones due to widespread use in CNC machines.
                                        On the accuracy/repeatability point.
                                        I've previously bought 2μm TIR ER11 straight shank holders to use with bearings shrink-fitted onto the shank to make a high speed spindle for an engraver, so in a small knee mill I would consider the impact of the holder minimal.
                                        Admittedly you would need to buy a similarly good collet to really make the best of that and you could potentially see additive effects, but even if the collet was 12μm TIR then you'd still be under 0.0005" (half a thou) which would be pretty good still.
                                        Edited By Jelly on 13/12/2022 16:50:25
                                        #624861
                                        old mart
                                          @oldmart
                                          I have a Cutwel 13mm/1/2" R8 integral keyless chuck which holds 0.01mm with any size I care to put in it. Just pure luck, the 0.05mm is good for a drill chuck and all the rest of our chucks at the museum come into this range.
                                          #624863
                                          Bill Phinn
                                            @billphinn90025
                                            Posted by old mart on 13/12/2022 21:24:01:
                                            It may just be because Cutwel's site has a dreadful search facility [besides being appalling to navigate generally], but apparently there is no Cutwel R8 drill chuck for sale any longer.
                                            #624982
                                            Martin Currie
                                              @martincurrie
                                              Hello Guys
                                              Thanks for the further comments, I was a little confused following some of the later comments, but now I’ve decided to go along the route of a ER20 collets. I’ve spoken to APT and will change my order.
                                              The reason behind this change is that I use milling cutters all from APT 4, 6 ,8, 10 & 12mm.
                                              I like the idea of having a smaller size chuck for visibility, chip clearance and having easy access to allow coolant into and around the work piece. I had a look at the dimensions of the ER20 holder and I agree with the above it’ll allow good visibility and I like the slenderness of the chuck compared to the ER32.
                                              I believe this will work well for my applications going forward.
                                              APT have a great selection of the collets that I’ll need, and they also state the TIR, I’ll begin with these and see where I need to go from there onwards.
                                              If I need a larger milling cutter, I’ll be looking at a fly cutter or an R8 face mill of sorts.
                                              Thanks for all your help.
                                              Martin
                                              #625111
                                              old mart
                                                @oldmart
                                                Good choice when you use cutters up to 12mm. My reasoning was slightly different when I chose er25 over er32, simply the cost of cutters over 16mm gets very high. For larger sizes using R8 collets, the straight shanked 12, 14, 16 and 20mm with APHT or APMT inserts are economic to use and do not overshadow the work like a collet can. APT sell this type.
                                                #625126
                                                  For Milling Only then a smaller ER size is quite possibly a better choice but many look at the overall picture and go with ER 32 as they have a better range when it comes to work holding both on the mill in say ER blocks and on the lathe in a flange mount chuck. So one set of collets does all rather than having ER20, R8 for larger mill use and something else for the lathe.
                                                  #625135
                                                  Anonymous
                                                    Looking at the bigger picture I use ER20 on both my R8 taper mills for cutters, although not that often. Everyday milling is done with 6mm and 10mm endmills in sidelock holders. i've never used ER collets for work holding; I use Burnerd EC collets on the lathe.
                                                    #625154
                                                      I don't use my sidelocks that much but useful sometimes with the smaller cutters.
                                                      On the X3 with it's MT3 spindle I tend to mostly use ER32 but do have a ER16, a few MT collets and a few sidelock.
                                                      The SX2.7 tends to mostly be used with the ER25 on R8 that came with it plus the odd sidelock
                                                      KX3 is almost all done with an R8 ER16.
                                                      As for work holding on the lathe I was about to but an ER32 chuck for that but got a 5C chuck at a very good price so tend to use that, the %c collets also fit the Spin Indexer so hold most of my round work on the mill as well. Both have %C to ER32 for those odd sizes that I don't have 5C to fit. With both ER32 & 25 collet blocks I also don't suffer from the problem of wanting to hold work that is the same diameter as the tool shank I want to cut it with.
