Thanks guys,
KWIL I did consider cutting off the 5th rib, but I thought I might get an uneven cut by hand and I would still have the same problem of modifying a replacement next time round.
I guess the exact length isn't mission critical as the suppliers I have found list 483mm not 475mm. I have some tension adjustment on the motor pulley.
By the way what is the convention on listed belt sizes? Is it inside diameter or outside or even the trough of the v?
Also is there much of a quality difference in brands, or a few brands that are best to choose from?
