Looking for cast iron
Home Forums Manual machine tools Looking for cast iron
  • #618288
    old mart
      @oldmart
      sam_0800.jpgI have long put off making a replacement cross slide for the museum's Smart & Brown model A because of its size. Recently, I realised that the limited throat depth of the mills would not prevent me from making a new copy of the cracked original. The radius of the cross slide from the compound to the rear end is about 14 inches, but there is no need to be able to rotate that more than about 200 degrees to be able to mill the dovetail. Now I am looking for a piece of cast iron about 18" by 6" and just over 1" thick. SG iron would be better for its ductility than grey iron. Everything depends on the cost, I might have to give up if it is very expensive. Does anyone know of a source?
      old mart
        @oldmart
        #618291
        HOWARDT
          @howardt
          Fixture component suppliers are a source, such as WDS, not cheap but it is proof machined. Used to use a lot of their sections over the years.
          #618293
          HOWARDT
            @howardt
            Alternative would be to use steel and Turcite the way surfaces.
            #618294
            peak4
              @peak4
              You could try United Cast Bar in Chesterfield
              https://www.unitedcastbar.com/
              Bill
              #618296
              Jelly
                @jelly
                Best bet would be to ring commercial stockholders and ask them to process you the blank you need from a standard size product like 150*150 square; a big stockholder who carries lots of CI will hopefully carry rectangle sections in suitable size, saving you some hassle and cost.
                But for what you pay in cutting fees, you offset not buying the additional 5" of thickness on that bar so it's always worth pursuing that. If they're regularly selling CI or Special Steels this kind of thing should be pretty normal for a stockholder…
                • West Yorks Steel have always been great for me with small orders and special cuts (mostly die steel), and do carry cast iron in many grades.
                • Colt Material Solutions carry significant quantities of CI in a range of grades with defined properties including ductility and vibration damping.
                • M-Machine Metals Carry large section cast iron as both GR17 and SG, but oy as square or diameter, I don't know that they have the same processing facilities as the others, but are worth approaching.
                Edited By Jelly on 22/10/2022 22:08:01
                #618298
                Paul Lousick
                  @paullousick59116
                  Have another cast at a foundry. Make a simple pattern out of wood that is slightly bigger than the 18" x 6" x 1" thick shape. Tell the foundry that it is for a museum and not needed immediately and they may make it for the cost of material when they are pouring something else.
                  #618326
                  Pete.
                    @pete-2
                    Have you thought about bronze tig or mig? I've had pretty good luck experimenting with it on cast iron, if it's just that little crack in your cross slide it wouldn't be a huge amount of work.
                    #618329
                    DC31k
                      @dc31k
                      Is the projecting part at the other end to the circular slot simply for attaching the taper turning attachment? If so, could it be made of a separate piece bolted on, thus reducing the overall size of the stock?
                      Perhaps mill away the entire outer dovetail, replace it with a steel ring, bolted in place and remake the dovetail. It is not a high speed sliding surface and steel is better able to resist the tensile force induced by the wedging action of a dovetail bolt.
                      A better repair than the underslung splint, and one that has the potential to apply force to close the crack might be to mill out a bow-tie shaped part in the top and glue in a spline piece (just as woodworkers do for repairing cracks). You make the spline slightly small and heat it up before inserting into its pocket. As it cools, it shrinks and pulls the crack together.
                      #618333
                      Ady1
                        @ady1
                        Agree with the welding option, tig best, mig possible
                        To my eye, it doesn't look like there is enough meat there to begin with, and that's why it cracked
                        Presumably it's a non-loading point
                        #618341
                        ega
                          @ega
                          old mart:
                          I enjoy your posts and wish you well with your search for CI.
                          My own wish is to know which museum you invariably refer to. Might you put it in your profile?
                          #618386
                          Pete.
                            @pete-2
                            Just out of curiosity could you tell us what's wrong with the bracing piece you've put on? Is it not working sufficiently? Or just not keen on the look of it?
                            #618398
                            old mart
                              @oldmart
                              The design is basically weak, but does allow the tailstock to be closer to the spindle than my bolt on repair. If I were to make a replacement, it would be stronger by design, even if made from the same type of cast iron. The outer curve could be at a larger radius, with its centre to the left of the original, leaving the width at the centre the same. This would add more material to the ends of the curved section. The thickness of the outboard curved section in a vertical plane could be greater, the extra underneath would not restrict the tailstock or the movement, which is about 7" total.
                              I have no idea when the damage was done, or whether it was caused by overtightening the two compound holding bolts, or crashing into the tailstock. The reinforcement was accompanied by doubling the bolts to 4 and not tightening them as much. The lathe was due for scrapping when it was donated to the museum.
                              Thanks for all the suggestions and links, I will be finding out
                              I agree about the length, I had originally contemplated making the rear end a separate add on part to reduce the radius, but below 11" rad would reduce the length of the dovetail length more than I would like.
                              #618410
                              Pete.
                                @pete-2
                                It's hard to be completely sure from looking at those photos, but I get the impression the radius overhang is weak, what I'd do is use a die grinder to carve out the crack enough to fill with bronze, then make two little gussets with some scrap cast iron and braze those in place underneath to support the overhang.
                                Some experimenting with bronze cast Iron repairs.
                                #618916
                                Pete.
                                  @pete-2
                                  Did you ever find a solution to this? If you can't find a cost effective solution I'll bronze braze it for you FOC, you'd need to cover the postage and send a couple of small bits of cast iron that could be used as gussets, I'd imagine some bits of scrap from anything would do .
