Posted by john willman 1 on 15/10/2022 12:17:11:
Since most machinists turn the topslide to half the thread angle and so that the tool only cuts on one flank, having the retracting part at right angles is quite useless. I never found a use for it !
It should still retract the tool out beyond the OD to clear for reverse traverse, should it not? Then reset the retraction and then add the next depth of cut on the topslide dial?
Seems like it would be just about as easy to wind the cross slide dial. But perhaps the quicker action of the retractor allows you to cut closer to a shoulder or to screwcut at higher rpm, which is always very handy.
