Centec 2b
Centec 2b
Home Forums Manual machine tools Centec 2b
  • #609358
    Sean Stimpson
      @seanstimpson39664
      Hi all I recently brought a Centec 2b local to me very cheap with a quill head
      Didn’t realise the size of the swarf tray
      2 questions
      I need a new bellows for the z axis lead screw what do people use
      also I use carbide end mills don’t have hss I find 1400 rpm a little slow for using the vertical head
      do people change the motor to a more powerful 2 pole or play around with different size pulleys thanks in advance
      Sean Stimpson
        @seanstimpson39664
        #609366
        peak4
          @peak4
          Re the bellows, it's not very elegant, but I use a modified macadamia nut tin to provide a shield/mounting for the lower end and a corrugated shock absorber cover for the main bellows unit.
          It seems to work fine.
          I'm not sure I would want to run the main gearbox as fast as a two pole motor.
          Maybe consider a second variable speed motor to replace/drive the rear V pulley on the vertical head.
          Bill
          #609367
          duncan webster 1
            @duncanwebster1
            Vertical head gets pretty hot if you run for extended periods at 1400 rpm, I wouldn't want to run it any faster
            #609369
            peak4
              @peak4
              Posted by duncan webster on 12/08/2022 18:17:10:
              Yes fair point, and also worth considering removing the chuck, if on MT2 taper, whilst it's still warm, to save it jamming tight when it cools down.
              Don't ask me how I know.
              blush
              Bill
              #609370
                Too late by then. That will make no difference at all. Problem arose when a cold taper was inserted into a warm socket.
                #609409
                Gary Wooding
                  @garywooding25363
                  On my 2B I kept the original 3ph motor, converted it to delta by splitting the star point, and run it with a VFD. This gives me a speed range from about 30-2800 rpm. I've not experienced problem using carbide tooling, and it makes tapping under power a doddle.
                  #609410
                    Posted by Gary Wooding on 13/08/2022 08:04:25:
                    Almost exactly the same except I changed mine, from the (non-original) single phase fitted, to a 3 phase motor.
                    I’m not sure whether the vertical head rpm’s are the same as the horizontal output – I’ve simply never checked.🙂. I don’t thinkI’ve ever exceeded about 2000 (indicated rpm) on mine.
                    The power feed is operating perfectly adequately using the 3 phase motor and a 240V VFD.
                    I would not actually recommend a more powerful motor. The 2B was increased from 3/4HP to 1HP (over the 2A model). I am not aware if the gearbox internals were changed at all. If not, that is already a 33% increased rating. Mine can actually deliver about 1.2HP, but I am careful not to use all the power available. My Centec is a valuable asset and I don’t intend to try to destroy it by over-loading it!
                    #609411
                    Sean Stimpson
                      @seanstimpson39664
                      Is you Centec 2b motor a 2800 rpm motor as standard mine is only a 1400 rpm
                      #609470
                      duncan webster 1
                        @duncanwebster1
                        Posted by not done it yet on 13/08/2022 08:32:49:
                        I’m not sure whether the vertical head rpm’s are the same as the horizontal output – I’ve simply never checked…..
                        There is a 7:8 ratio between, can't remember which way
                        #609594
                        Dave Halford
                          @davehalford22513
                          Centecs were available with 2800rpm motors. There has been a previous discussion on here.
