Hi All…
Have been restoring the lathe over the past few months and I was thinking of writing a series of articles for MEW but have now decided to just put the log on the forum.
For those who remember the picture below shows what it was like the day I got it delivered, I asked a certain editor what he thought of it, to which he replied that it looked like a badgers bottom..! Cheeky b****r
The whole point of having a restoration project as this is to do as much as I could using the tools and methods that I have at hand and as economically as possible, otherwise I might as well go an buy a new one, so I make no apologies if some of these methods are not exactly industry standards, however I have used these same methods to restore an older lathe which has been quite remarkably accurate and is now a joy to work with.
It has certainly been interesting and educating, and most enjoyable to bring something back to life.
The saddle & cross-slide looked particularly nasty..below, totally locked up with rust.
The clutch & pulleys being covered up were not so bad ..
The main thing with this big lump is that it is quite heavy, I used a wheeled hydraulic motorcycle lifter so that I could move it around, the plan is to completely dismantle and start off cleaning the bed up.
The bedways when cleaned up showed that there was ~ 5 thou" wear at the headstock end, there were other dings and dangs but I was pleased that it was not too bad and was something I could take on as a scraping project. I have a large-ish surface plate which I used to check flatness, the main problem being that without lifting gear I would not be able to put the plate on the bedways, the only way I could tackle this problem was to lift the bed up on the hydraulic lifter to the same height as the plate and gingerly roll in on the plate.
Hope this might be of interest to some of you good folks, I have quite a lot of pictures to upload as yet and I think you will be surprised at what it looks like now.
More to come. Bob.
