3.5″ Jubilee Drawings
Home Forums Locomotives 3.5″ Jubilee Drawings
  • #198969
    Brandon Thorn
      @brandonthorn58894
      Does anyone have a set of second hand Jubilee drawings in 3.5" Gauge?
      Cheers,
      Brandon
      Brandon Thorn
        @brandonthorn58894
        #198975
        nigel jones 5
          @nigeljones5
          Yes…if i can find them
          #199009
          Trevor Drabble 1
            @trevordrabble1
            Brandon, I also have a set of old but unused drawings available should Fizzy not be able to find his .
            #200043
            Trevor Drabble 1
              @trevordrabble1
              Fizzy,
              Have you been able to find these drawings yet please ?
              #200050
              nigel jones 5
                @nigeljones5
                just emailed you – again
                #200051
                nigel jones 5
                  @nigeljones5
                  no i didnt! (email you that is!) found them all
                  #200095
                  J Hancock
                    @jhancock95746
                    Watch out for uncorrected errors around cylinders, valve gear , brake operating rods, etc.
                    #200113
                    nigel jones 5
                      @nigeljones5
                      Oops – Having spent hours searching for and then scanning these I now realise they are in fact JULIET !!
                      Sorry!
                      #200121
                      Steve Papworth
                        @stevepapworth83993
                        Having built a 5" Stanier 2-6-4, I started by enlarging the "Jubilee" drawings (from ME), but after acquiring a dimensioned GA (published in Railway Modeller, I think), I realised that Martin Evans had made everything very over scale.
                        Send me a PM, and I can send you a PDF of the GA, as well as a JPG of a side-on photo of a full size one, just out of the shops. (The same picture that was published in ME).
                        Steve
                        #200136
                        Brandon Thorn
                          @brandonthorn58894
                          Pm sent
                          #200271
                          David Reeves 1
                            @davidreeves1
                            Plans available from My Hobby Store. £47.50.
                            http://www.myhobbystore.co.uk/product/17308/jubilee-lo23
                            Dave Reeves
                            #200395
                            Brandon Thorn
                              @brandonthorn58894
                              Thanks David, I was wanting to buy a set of second hand drawings because I am not quite convinced if I want to build this loco right now or not.
                              #496046
                              Ben Gladwish
                                @bengladwish12137
                                Hi I recently purchased a 3 1/2 inch jubilee part built but I'm in need of the instructions, does anyone still have instructions? Many thanks, ben
                                #496109
                                J Hancock
                                  @jhancock95746
                                  And when you get them draw out a plan view around the valve gear on squared paper where 1/32" =1/10th ,
                                  and discover nothing fits, if you build it to the drawing dimensions !
                                  #496111
                                    Sarik now sell the plans here
                                    #496113
                                    Ben Gladwish
                                      @bengladwish12137
                                      As this has most parts do these plans show where the pipes and valves etc are run and situated? I'm a real amateur and jumped in at the deep end, thank you👍🏻
                                      #496121
                                      J Hancock
                                        @jhancock95746
                                        Better that you don't fit the brake gear as drawn or you will never be able to drop the ashpan.
