Hi Chris.
Do you have the spares manual for the machine? It shows the numbered breakdown/exploded view of the head, quill and gearbox.
I have three of these machines so know them reasonably well, but to try help it would be easier to refer to the numbered elements in the exploded view.
When you say you have stripped the head down – to what extent? Have you removed the Drive pinion, item-6?
You have removed the quill (41) from the head. Does sliding drive gear ( 12) slide freely along the quill spline?
In the exploded view, page 10 in the manual, remove all the elements in the vertical line above the quill ( 41), as well as all items associated with the spline drive pinion, item-6 on page 8 , and the quill alignment screw (15 – page 8). Also ensure the quill locking screw ( 43, page-8) is loose.
Then can you insert the quill into the head form either top or bottom, or both, and see if the quill sticks and where it may stick? You may already have done this..
If loose from the top till it almost exits the bottom, then I suspect the split clamp at the bottom is bent or twisted – although prudent use of marking blue should have shown this.
Please expand a little on your statement –
I've applied engineers blue looked for obvious tight spots. I've used a light emery on any possible issue spots, but the thing is still tight.
This makes no sense at face value – if you coated the entire quill outer (needle bearing case) shell with blue, and it shows no mark-off on the inside of the cast iron shell in the head, it cannot be stiff…
Can you post some photos of what you have done?
When you say the MT is seized and you resorted to the hammer, do you not have the draw bar and top nut release mechanism? I presume that when you did the hammering you did not support the quill exit-taper with a forked support? That is most unfortunate, as in that quill the needle bearings, which are a very specific pre-load fit, take the full brunt of the knock, end on, and that invariably leaves micro 'dents' in the bearing surfaces at the needle ends. The end bearing in the business end of the quill also suffers the same fate..
There is a section of the quill outer, around 1/3 down from the top, that is thinner in wall thickness than the rest of the tube. The bearing above this impinges on an inner flange section above this thin wall, and if the flange is bent downwards, the outer wall cab bulge, or bulge in an oval fashion. That will cause stiffness for sure! However, marking blue should show this right-off. You can also Mic the outer diameter all over, checking for better than 0.02mm…
When this 'ovalling' has occurred, it is generally accompanied by a stiff spindle in the quill as well – thats the end of the quill, if so!
If you do not have the manuals, I can send you the PDF if you PM me you info, or I can post images here, but the resolution will suffer as there images I have are BMP and I have to convert to JPG for the posting. I also have PDF..
Joe
Edited By Joseph Noci 1 on 05/10/2020 08:43:16
