I got pretty good with the Picador device and found the device in older Plasplugs sharpening system to work respectably well and reliably despite the cheap'n nasty plastic construction. But using the Picador was always something done when I had a bunch of drills to do as there is a certain knack involved in getting the drill held correctly.
Then I found a drill sharpening attachment for my Clarkson T&C grinder at a silly low price due to a couple of missing parts. Eventually got round to sorting it out and now its essentially permanently mounted so any drill needing sharpening gets done immediately. Takes about 2 minutes. Results are sharp, really sharp every time.
So far as I can see the basic geometry is the same as any other swing across the wheel system albeit swinging vertically rather than horizontally. But the construction is industrial style massive and the drill is held in a good quality 6 jaw chuck making setting the correct stick out ,1/2", and cutting edge angle, horizontal),very easy. The chuck is on a hollow spindle, to accommodate main length of the drills, with an indexing collar on the back so flipping 180° to do the second edge is easy and accurate. Having the T&C screw adjustment and lever travel slides does make setting up the correct grind really easy.
The inherent issues swing across the wheel sharpeners of Picador or Spiralux / General et al clone seem to relate mostly to the Vee block style carrier. Inexpensive but it does need a practiced hand to repeat well. The instructions are always inadequate. Although they more or less tell you what to do they are little help when things go wrong. Very easy to lock into a bad technique without realising it. When it comes to the import clones it really doesn't help that many are made with fundamentally incorrect geometry.
Now respectable quality drill chucks can be got at reasonable prices it seems to me that the time is ripe for a good DIY device design using Clarkson or Kaindl **LINK** geometry with a bored out drill chuck to carry the drill and a suitable index plate for flipping. Kaindl being possibly more practical geometry as it runs over the periphery of the wheel so you don't need a cup wheel and dressing back flat is easier. A screw driven grind depth adjustment system is of course essential.
Edited By Clive Foster on 11/06/2020 13:51:53
Edited By Clive Foster on 11/06/2020 13:52:26
