Posted by mechman48 on 13/11/2019 17:49:03:
Some owners have replaced the gear system with a belt drive set up which will eliminate the problem altogether giving any 'jam ups' the opportunity for 'belt slip'. IIRC there is a USA site that has the material to do this …'Grizzly' & if I remember there was a write up to do this on their version… Grizzly 0704 I believe, have a look see. I have considered doing this mod with mine but as the old engineering cliché goes… 'if it aint broke don't fix it ' so…
I have now done away with the plastic gears altogether in my WM16 and installed the "belt conversion" designed for the G704.
Benefits are twofold – cooling is now not a problem as the motor is now left exposed (instead of cooped up in the cover) and if anything jams, the gears are not stripped. However, the underpowered 750w motor of the WM16 stalls long before the belt can slip. There is a 1100w motor available that can be substituted so when the 750w goes, so I'll be looking at that as a replacement.
The only slight niggles are that the drawbar is no longer self-releasing (due to the new belt drive spindle) and as the problematic hi/lo gear is no longer used, the speed change is now by changing the belt between two different sized pulleys. Not major hassles by any means.
Expensive conversion though (£600ish) and if I hadn't already spent time and money upgrading the WM16 I would probably have just bought an alternative mill.
Edited By William Hepburn on 30/07/2022 14:05:09
Edited By William Hepburn on 30/07/2022 14:06:07
