I am in a quandary as to what to do with a Lenz LPA 1s automatic boring head I have acquired.
It looks to be in good condition and the first ring on the head (lower ring) certainly moves the slide left and right but then I realised the second ring (Upper) did nothing even when the engage plunger was pushed in.
![first.jpg first.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
On investigation the upper section seems to be missing a number of vital components…
Plunger would have activated a second inner wheel (toothed cog) however there appears to be a ball / tooth missing to engage the wheel. This is an easy fix…
![second.jpg second.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
But then I realised that with the inner wheel engaged…. There is a ???? missing to connect the inner ring to the second ring. The second ring appears to have a mechanism similar to a brake, or engagement lever. The wall also appears to have a ridge applied to it so that something can temporarily lock in place….
![third.jpg third.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Does anyone have an exploded diagram of this type of head as I have trawled the intraweb thingy and there is nothing?
Any help restoring this would be appreciated.
Dan
