drafting
drafting
Home Forums Locomotives drafting
  • #120844
    Peter Dickson
      @peterdickson
      I am trialing a number of drafting measures on a loco built to the ashford design.
      I would be interested in comments with regards the performance of lococ built to the Evans drawings and any modifications applied
      Peter Dickson
        @peterdickson
        effects of changes in petticote pipe and blast pipe diameters
        #121635
        julian atkins
          @julianatkins58923
          hi peter,
          the greenly 1:3 and 1:6 cant be bettered IMHO.
          a slight divergent taper on the chimney is supposed to be advantageous ie 1.5 or 2 degrees (though ASHFORD has a short chimney). the fullsize rules dont quite apply to miniature because the exhaust pressure is much lower as per the findings of the late jim ewins. jim didnt like the idea if applying sam ell/swindon draughting to miniature locos and decided the swindon 'bell' to the bottom of the petticoat pipe to be superfluous but there is no harm in adding a 'bell' if space permits.
          have a close look at the correspondence at the time about the S15 valvegear and ASHFORD's in ME at the time from don ashton.
          cheers,
          julian
          Edited By julian atkins on 06/06/2013 00:19:48
          #121795
          Peter Dickson
            @peterdickson
            Thanks Julian,
            I have opted for 2 deg on chimney , I have made a range of blast nozzles, I am still not sure of any benifit in having a small divergent taper at the end of the blast nozzle..
            this appears in many greenly designs but nowhere else
            #121848
            julian atkins
              @julianatkins58923
              hi peter,
              the divergent taper on some blast nozzle designs seems to be a throwback to what steam does at high pressure when existing a nozzle… as in the steam cone of an injector. i dont know enough about gas flow to be able to comment on whether it has any effect on a blast nozzle in miniature by way of reducing the 'spreading out' of the envelope of exhaust steam in the smokebox… it seems very doubtful to me due to the very low pressure of the exhaust in miniature and the fact that the bigger 'envelope' the greater the vacuum created.
              i have always made the nozzles with a short converging taper finally a short parallel section. of crucial importance is getting the chimney to be concentric with the blastpipe. ive also made quite substantial alterations to a few cylinder blocks to avoid a 'bent pipe' blast pipe and instead have a straight blast pipe which is as rigid as possible.
              cheers,
              julian
              #121924
              RRMBK
                @rrmbk
                Might be worth looking at locomotive Draughting, M.E. July/ August 1989. Contains some interesting data and drawings.
                #124466
                Peter Dickson
                  @peterdickson
                  Brian,
                  found it brilliant many thanks answers all the questions
                  best regards Peter
