Hi Rob.
Short answer is no. You use the big burner to provide background heat on the outside of the fire box and use the cyclone burner to solder the stays on the inside. Cyclone pulls in air from near the handle…
Ray you should be able to build a 3.5″ boiler with propane only – again using two torches (ideally with two people) for the later work when putting the inner and outer parts together. I used copper rivets for stays and silver soldered everything.
Oxy-acetylene will get you out of a jam so it’s handy to have to it but not essential.
I’d strongly recomend step soldering using three different grades of silver solder for peace of mind. I used Silverflo40, Silverflo55 then EasyFlo2.
Cheers
Bryan
