I am looking at the different types to get a better picture of all.
The other day I made a test cut with new boring head, I actually used the boring head/bar-Insert itself to centre the head above at 1st,… and then in the hole by listining to the boring bar tip as it go around, mill switched off, turn and adjust by hand, you don't want to break a bar or the head turning it on. It worked out after some effort.
These tools may not work out always:
I then realised there might be a situation, and thats a situation I might have to deal with if my current quick plan proves not to work out for restoring the RF 115 Rong Fu bandsaw which was dropping blades when I received it, a situation where indicating with a tool like this means not much if the bore has been weared out uneven.
So in a case like this, where you want a shaft to line up correctly from your boring and sleeving excersize, you must find a ring visible outside of the wear pattern(Hole) to indicate the original alignment and to the centre of your spindle. So in this case I will probably using the boring head and bar insert tip to get the job done right, time consuming but hopefully lined up correctly.
Note:It seems these tools has a very interesting point in design apart from what was mentioned above, and that is its accuracy of indication depends on two surfaces, maybe 3 in the design, otherwise its not effected.
That brings me to a point after some thought, one could use this tool straight in the boring head and let it swing from there, use that adjustment initially to set it up, then let it swing slowly and it will move but still faces you and get the job done uneffected, I never saw anybody uses it like this-?
Make a tool:
I can attemp to make such a tool shorter(More headroom) but then the indicator will sit sideways and not in path and upright, and it will not be accurate, but will only indicates movement of not being on centre, so you cannot off centre someting to an exact figure if you want to.
Wiggler:
I also thought of using the wiggler stiff tightened to indicate a circle, but not in the way a wiggler is normally used.
Lazer lights:
I also saw use of small lazer lights that just clip over spindle and shine a circle which you then position.
This seem interesting and easy.
What do you think-?.
Edited By Chris Mate on 20/08/2023 16:50:08
