I have been asked to produce some small gear wheels.
The dimension of the sample is as follows.
Diameter across the teeth…….0.467"
Approx PCD…………………..0.400"
Number of teeth ……………14.
Using my limited knowledge of gear cutting. I work out the cutter would be
36 DP number 7 cutter to be the cutter required. Could anybody confirm my calculations ?
