Hello:
Posted by JasonB on 24/06/2023 06:51:13:
… grind a 1mm radius on the end and then ….
Done by taking a stepped approach similar to the one suggested.
This is the tool+holder as used. Not the prettiest but it worked as I intended.
Some with better eyesight than what I have may notice that the bit is not at exactly 90° to the holder and that the hole is larger than the bit. Vice moved, milling table clamps are still on the to-do list.
In any case, as the bit was to be registered against the one of the faces of the pulley and a larger hole did not pose a problem, that was that.
The front end of the bit was ground with a slight slant (maybe 10/15°?) but left at ⌀ 5mm to keep the width of the groove constant and parallel / even. Once centered, it was very slowly fed into the piece till I had an almost square ended channel ~ 3.5mm deep, the almost due to the slant and the cutting edge being a bit lower than the centre.
Granted, it is not the most orthodox technique but it worked quite well to start off the groove both parallel and at the right width in just one albeit very long operation.
The use of a 6x6mm straight finishing tool with a large radius tip was the next step to gently sneak up to the desired inner radius and the rest was done by hand with the end of a rat tail file with an end that is ~ 4mm.
Looking back, I could have waited to purchase a round file such as the ones used to sharpen chainsaws. They come in small diameters (5mm/6mm, etc.) and have a spiral cut pattern which will probably work for this job.
I will probably purchase one for when I turn the pulley for the milling head which is also plastic. Curiously enough (or maybe not) Emco decided to manufacture it with a M12x1 mount instead of the 14×1 one used in the U3. 8^°
Right …
Here is the finished product, tested to run evenly and ready to use:
I got the idea of making a M14x1 mounting hole at the rear facing side of the pulley from the steel pulley that is part of the lathe threading attachment (part #150250) which has a small threaded hole.
I have not used it and probably never will: I only have one chaser and I found it very awkward to both mount on the U3. I find the thread cutting attachment (#150200) is much easier to deal with and use.
This mounting hole could be useful for many things, eg: turning long pieces of round stock and keeping it straight by means of a tube screwed into pulley. It would turn along with the pulley and be true with the spindle axis.
A 100/150mm length should not be a problem and stock up to just under 10mm could be turned without the strain that it would put on the chuck jaws if it were just dangling through the other side of the spindle. Stock with smaller diameters could be guided by means of a plug with a hole of the right size at the end of the tube.
That's all.
Thank you very much for your input.
Best,
JHM
Edited By Julius Henry Marx on 24/06/2023 14:06:51
