Posted by peak4 on 14/10/2022 01:50:22:
Posted by Robin Graham on 13/10/2022 23:10:36:
On penetrating oil – I remember reading ages ago that the best thing is a 50:50 mix of acetone and … something. I think 'something' have been ATM fluid – can anyone confirm?
Robin.
Either a typo or difference in nomenclature.
ATF, as in the red auto transmission fluid.
Bill
I wish I could claim that it was a typo, but F and T too far apart on keyboard for that to be plausible – a brain rather than finger slip I'm afraid!
I made up this concoction and no joy, so I though I'd have a go with the 'welding a nut on' before resorting to drilling. To my surprise (I'm terrible at welding and there wasn't much of the sheared screw protruding) it worked! Maybe the heat had something to do with – it came out fairly easily.
As it would have been a couple of days before I could get down to my local supplier for 2BA screws I thought I'd have a go at faking them up myself, so made some bits of 3/16x32TPI stud on the lathe and welded on M6 nuts. Not pretty, but they worked. It'll be one of those stopgap fixes which never get 'done properly' I suspect. I have only 60 degree threading tools, so maybe not quite right, but the internal threads in the CI are pretty roomy and forgiving.
Anyway, thanks to all for advice – problem solved, and workshop is now running at a tolerable 17.5C.
Robin.
Edited By Robin Graham on 17/10/2022 21:52:51
