Boiler test
Boiler test
Home Forums Beginners questions Boiler test
  • #609217
    Michael Brett 1
      @michaelbrett1
      Hi all
      Need help in identifying boiler threads prior to sealing and testing for leaks. I have three holes to seal , inlet and outlet , and one for pressure gauge.
      Inlet and outlet are male threaded , the closest I have tried is 3/8 x 32 tpi. This size union nut starts to go on then jams. Looking at thread I would say this should be a 3/8 buy 28 tpi as the thread is a little courser. I have tried the internet but cannot find this size , is it USA size.
      The third inlet is for the pressure gauge and is female. Again the closest I can find to fit is a m6 tap but this soon jams after a couple of turns.
      This is an old boiler but very well made so would like to eventually get it u and running.
      Thanks in advance Mike
      Michael Brett 1
        @michaelbrett1
        Sealing boiler inlets prior to test
        #609222
        Jon Lawes
          @jonlawes51698
          I googled 3/8 x 28. I would suggest you get a thread gauge to be sure before spending money though.
          Can I respectfully suggest you pause before going too far; jamming in an M6 tap to an old boiler sounds like a disaster waiting to happen. If its an old british boiler I suspect M6 won't be an option and you could be causing damage by trying.
          Some people recommend using a soft wood or even wax on internal threads, then withdraw the wood and measure the TPI on that.
          #609228
          noel shelley
            @noelshelley55608
            A likely contender is 1/8" BSP at 28tpi, 0.383" od, could be 3/8" 26tpi. For the near 6mm try 0Ba.  Noel
            Edited By noel shelley on 11/08/2022 17:43:29
            #609233
              3/8" x 26 sounds likely for the larger ones and the smaller could well be 1/4" x 26
              #609241
              Harry Wilkes
                @harrywilkes58467
                Check out some of the ME thread sizes, ME very popular in model engineering yes
                H
                #609243
                Michael Brett 1
                  @michaelbrett1
                  I tried my 1/8 npt 27 die and it screwed on all the way , bit sloppy but I assume because of the taper
                  Do they do a 1/8 bsp in 27 or must it be 28 or 26.
                  #609245
                  Michael Brett 1
                    @michaelbrett1
                    Found and ordered BSP nuts for 1/8 x 3/16 od tube. Seems about the right size , at only 99p each worth a try
                    Just the smaller one to sort out now, will try 1/4 x 26.
                    Many thanks mike
                    #609254
                    Speedy Builder5
                      @speedybuilder5
                      Michael, please be aware that even manufactured nuts etc are made to tolerance, however I am not so sure how well the finished product is inspected. I bought some union nuts from one of our suppliers which would not fit other manufactured fittings before I ran a plug tap through them. I found it quicker to correct a dozen nuts than send back etc.
                      Bob
                      #609258
                        1/8 BSP is 28 tpi WHIT form. (55 degree thread form )
                        If it is 1/8 NPT x 27 tpi it will be a 60 degree thread.
                        So check the thread with the correct thread gauge.
                        Getting bit wrong, and forcing on an incorrect fitting could result in a damaged boiler.
                        At best,with incorrect fittings, it will probably fail because of leakage at the fittings..
                        #609261
                        noel shelley
                          @noelshelley55608
                          If the boiler was made in the uk then it can be assumed to be BSP as your guess at 28 correct and sloppy because you were using both wrong tpi and thread angle plus a short thread. Measure the od ! if it is .383" it's pipe thread ! Under 375" could be 3/8" 26. Noel.
                          #609279
                          Paul Lousick
                            @paullousick59116
                            As listed by Jason, 3/8" x 26 tpi (British Standard Brass thread) is a common size used for fittings for model boilers and engines. (not to be confused with American bicycle thread which has a 60 degree thread angle instead of 55 degrees)
                            Edited By Paul Lousick on 12/08/2022 00:36:38
                            #609282
                              A good thread pitch gauge is a small but valuable investment. It's the only way you can be sure of what you are working with. Screwing on commercially made fittings in trial and error can give a false result due to manufacturing tolerances and could damage the boiler fitting.
                              Edited By Hopper on 12/08/2022 05:02:52
                              #609301
                              noel shelley
                                @noelshelley55608
                                Hopper is spot on, but there are so many different thread rates that on a short thread piece, maybe less than .5", that if you have 2 rates only 2 tpi apart and may be a metric option as well it may prove hard to decide which is the right one. Then there's the thread angle, again on small sizes ti is almost immposible to spot 55* and 60*. Manufacturing tolerances will then mislead you as to the size OD. IF it feels right, is neither tight or loose and runs on nicely, pitch gauge and OD tally, it will be near enough ! Good luck. Noel.
                                #609305
                                Circlip
                                  @circlip
                                  It could be helpful in cases like this that the O/P gives their Universal location. This COULD give an indication of what may have been the threading system used in that location.
                                  Regards Ian.
                                  #609324
                                    Add a magnifying glass — one with the high power inset lense — to the thread pitch gauge shopping list.
                                    #609349
                                    Nigel Graham 2
                                      @nigelgraham2
                                      I was faced with a somewhat similar problem recently, with a thread on an engraver spindle.
                                      As well as using thread-gauges and magnifying-glass, I made some brass test-threads in bits of bar, to what seemed the measured size, and tried them – very cautiously.
                                      If they start to stick within 2 or 3 turns, they are obviously wrong; don't try to force them further.
                                      Note the threads must be scrupulously clean so you don't risk a bit of swarf jamming or tearing the threads, and I lubricated them with a little spot of WD-40 or white spirit.
                                      (It actually turned out to be a 30tpi Unified Special, of all things!)
                                      #609361
                                      Michael Brett 1
                                        @michaelbrett1
                                        Many thanks for all your advice. I do intend to make some test pieces using brass hex bar. I think I am getting close to finding the correct size , having found out what does not fit. Job is on hold at the present as my workshop is just to hot to work in, I would rather take my time so as not to damage anything.
                                        Cheers Mike
                                        #609374
                                        Harry Wilkes
                                          @harrywilkes58467
                                          Posted by Michael Brett 1 on 12/08/2022 17:32:07:
                                          Cheers Mike
                                          If you do sort it please let us know what the thread in question is
                                          H
                                          #609400
                                          Paul Lousick
                                            @paullousick59116
                                            A simple method for measuring the pitch of an internal thread is to screw in a piece of wooden dowel and measure the the number of grooves/inch which are left on the wood.
                                            #609455
                                            Michael Brett 1
                                              @michaelbrett1
                                              Progress at last
                                              The two male threads turned out to be 1/8 bsp for 3/16 od pipe. I found a bolt that fits the female pressure gauge union perfectly. Tried to measure it with my thread gauge and it comes up as 1.25 not sure what that means.
                                              Anyway sealed boiler and did a hydraulic test . Only got to 70 psi and there was leakage from bottom tap on gauge glass, need to sort that out. Plus a water leak where elbow screwed into top of boiler , again got to get some suitable loctite on that. Will do another test later in week.
                                              Happy days Mike
                                              #609459
                                              Harry Wilkes
                                                @harrywilkes58467
                                                glad you sorted out the threads good look with the leak
                                                H
                                                #609530
                                                Jon Lawes
                                                  @jonlawes51698
                                                  I wonder how much people read the previous posts before answering. Would save a lot of duplication.
