7/16 B S B Thread
7/16 B S B Thread
Home Forums Beginners questions 7/16 B S B Thread
  • #11141
    Former Member
      @formermember12892
      Former Member
        @formermember12892
        #588748
        RobCox
          @robcox
          British Standard Brass is used for brass tubing, gas fittings and general brass work (quoting from machinery's handbook here).
          It will be 26TPI, Whitworth form. Easy enough to make on the lathe if you've got the wherewithal. Whether you can find one off the shelf that easily is another matter.
          #588750
          Mick B1
            @mickb1
            Looks like you can get a carbon steel die for 4 quid from Tracy Tools.
            #588753
            Former Member
              @formermember12892
              #588754
              DC31k
                @dc31k
                If you just need something with a 7/16" x 26 tpi male thread on it to plug a hole, seek out a suitable BSCY (or CEI) fastener. PTFE tape is your friend and the 5 degree thread angle difference helps it to seal better.
                #588784
                RobCox
                  @robcox
                  Bill, if it's any use to you, I found this hiding in a piece of brass offcut:
                  The threads are about 1/2" long, 0.437" OD 26TPI, the flats fit the spanner it's pictured with. If you want it, PM me with an address and I'll drop it in the post.
                  Rob
                  #588791
                  Former Member
                    @formermember12892
