Emco Unimat 2B Arbor Size
Home Forums Beginners questions Emco Unimat 2B Arbor Size
  • #587939
    Manda
      @manda
      Hi folks.
      I have what seems to be a very, very old Emco Unimat 2B. I purchased a dividing head from a friend, with 40 and 48 tooth wheels, but the arbor/spindle and the corresponding bore for the 3 jaw from the Unimat mics out to 16.5mm and the dividing head mics out to 17mm. In short, my 3 jaw will not mount to my dividing head, though the 3 set screw holes do line up and are the same thread. Can anyone tell me the arbor diameter on a Unimat chuck known to be made by Emco? I am wondering if this chuck and arbor / spindle cap / whatever it's called are aftermarket, or something? My 3 jaw is not marked, though the 3/8 chuck in my tailstock is clearly stamped "Emco."
      I hate to buy an extra 3 jaw just to permanently mount to my dividing head, but if I must, c'est la vie.
      Amanda
      Manda
        @manda
        #587942
        Former Member
          @formermember12892
          #587945
          Manda
            @manda
            Hi Bill,
            Here's the critter in question; mine is identical.
            http://www.lathes.co.uk/unimat/page10.html
            #587949
            Emgee
              @emgee
              Bill
              I have alwaus thought the Unimat DB and SL models had M12x1 spindle and tailstock nose thread, also I have what I believe you refer to as dividing head an indexer that takes different count gears to use in the same head, mine has a M12x1 thread and is bored through 12mm.
              Emgee
              #587952
              Manda
                @manda
                Hi Bill.
                The thread is 12×1. However, the chuck mounts to the… spindle cap? Arbor? Idk the name of the piece – that screws onto that 12×1 thread. It is held in place by 3 machine screws.
                The chuck is intended to mount to the indexer in the same fashion, except it cannot. The bore in the chuck and the arbor are 16.5mm in diameter. The arbor on the indexer gear is 17mm in diameter.
                https://i.imgur.com/P4esRBf.jpg
                https://i.imgur.com/JEK0Slx.jpg
                Edited By Manda on 03/03/2022 15:00:21
                #587954
                Former Member
                  @formermember12892
                  #587956
                  Manda
                    @manda
                    Thread size is not the issue. The size of the bore in the back of the chuck is. The chuck does not thread directly onto the spindle. The chuck is screwed onto a spindle cap which is what is threaded 12×1.
                    #587957
                    Former Member
                      @formermember12892
                      #587963
                      Former Member
                        @formermember12892
                        #587964
                        Manda
                          @manda
                          Oh, no! I didn't mean anything you said was wrong. I just figured I was unclear. I am not certain of all the terminology involved here, which is certainly not helpful.
                          #587967
                          Thor 🇳🇴
                            @thor
                            Hi Manda,
                            May be that what you call a spindle cap is a backplate? As far as my old eyes can see from your imgur photos, there is no thread on on the indexer? Is something missing from the indexer? Would it be possible to machine an adapter that fits the indexer and has a M12x1 thread for the chuck? Or is the indexer just about 0.5mm too large?
                            Thor
                            Edited By Thor 🇳🇴 on 03/03/2022 16:55:04
                            #587969
                            Manda
                              @manda
                              Hi Thor,
                              It could be called a backplate. The Unimat manual I have doesn't name this part in the diagram of the chuck, sadly. The indexer is, as near as I can tell, complete. The chuck is mounted to the piece that threads onto the spindle with 3 countersunk machine screws. the bore in the center of the chuck rides on the "arbor" of that piece that threads onto the spinde's 12×1 thread.
                              The chuck mounts to the indexer the same way; the bore in the chuck fits over the nose of the indexer gear, and then is held with 3 machine screws. The nose of the indexer gear is .5mm larger than the piece that threads onto the spindle, so the chuck does not fit it. I just wondered if someone who had a Unimat SL or DB could measure that bore on their chuck, is all. I am trying to determine if somewhere between my lathe's build date sometime in the early 50s and the Unimat SL coming to market in the mid 60s, if that bore changed sizes, or if I have an oddball aftermarket chuck. I do not mind buying another Unimat SL 3 jaw, but if it won't fit my indexer, it's not going to help me.
                              Amanda
                              PS. I have no idea how to post pictures direct to the site. This forum works very differently from others, it seems!
                              #587971
                              Frances IoM
                                @francesiom58905
                                just look at “all threads” – box on right of screen under ‘latest posts’ and then follow to FAQs – obvious once you see and realise you have to put photos into an album then from there to insert into a post.
                                #587972
                                Thor 🇳🇴
                                  @thor
                                  Hi Amanda,
                                  Posting photos is a bit tricky, see here. Unfortunately my SL is now in use on my toolgrinder and the rest packed away.
                                  The Unimat SL manual can be downloaded here. So it seems that the arbor of the indexer is 0.5mm larger than the hole in the chuck. One option is to bore out the chuck so it fits the indexer (you would then have to make a new backplate/flange or turn a new register on the backplate). Another option is to make an adapter that fits the indexer on one side and the chuck on the other, you might loose some headroom.
                                  Thor
                                  #587973
                                  Ian P
                                    @ianp
                                    I've used this site for years but never noticed any FAQ's. I've just tried to find 'all thread' too and failed.
                                    Putting FAQ into the search box does not produce any results either.
                                    Ian P
                                    (re Frances IOM post above)
                                    Edited By Ian P on 03/03/2022 17:35:42
                                    #587977
                                    Thor 🇳🇴
                                      @thor
                                      Ian, if you click " View All Topics " under Latest Posts you will find Website FAQ's.
                                      Thor
                                      #587980
                                      Ian P
                                        @ianp
                                        Posted by Thor 🇳🇴 on 03/03/2022 17:44:10:
                                        Thor
                                        'View all Topics' does not appear on my screen from 'Latest Posts'. OK I'm being picky but the mention of FAQ piqued my interest.
                                        By default I set my view of the forum to 'Latest posts' and have never yet looked for post by the individual forum titles. I'd never come across the FAQ's and I suppose if the this website's own built in search does not know of their existence its unlikely they would contain anything very useful
                                        Ian P
                                        #587983
                                        Thor 🇳🇴
                                          @thor
                                          That is strange Ian, it shows up on my Firefox screen:
                                          One of the peculiarities of the Forum software?
                                          Thor
                                          #587994
                                          Manda
                                            @manda
                                            Hi all!
                                            Thor, the manual was a godsend. It says that the piece that threads onto the 12×1 spindle thread is a "flange" and that the "turning diameter" of the flange (the arbor onto which the 3 jaw fits) should be .669 inches in diameter… exactly 17mm. As my chuck has a *smaller* bore than this I am going to guess that the size changed at some point between when mine was made and when the SL was made. I will seek out an SL 3 jaw chuck, I suppose. THANK YOU!
                                            Amanda
                                            #588033
                                            Thor 🇳🇴
                                              @thor
                                              Hi Amanda,
                                              Glad to help.
                                              Thor
                                              #588253
                                              Graham Meek
                                                @grahammeek88282
                                                An adaptor flange which fits the Dividing attachment and held on by 3 countersunk screws. With a register to take the existing chucks would be my way to go. Three tapped holes between the countersunk screws would retain the existing chuck.
                                                The thickness of the flange is governed by the length of the spigot on the dividing attachment, but I would think nothing more than 6 mm for the flange thickness would be needed. Plus the spigot to take the existing chuck.
                                                This would allow things to be worked on without having to resort to re-chucking, if needed.
                                                Gray,
