Half nut skipping still
Home Forums Beginners questions Half nut skipping still
Viewing 25 posts - 1 through 25 (of 57 total)
  • #572989
    Steve355
      @steve355
      Vintage lathes 😢
      I have a problem with my Zyto lathe in that the half nut jumps, maybe 1 in 5 times I engage it. I thought it was due to the little rods in the cam being bent, but I’ve fixed that (see wonky threads thread) and it is still doing it, it’s a problem it has only developed recently.
      I have tried all sorts of things, adjusting the gibs, tightening the spring that holds the lever, really everything.
      sometimes it engages very smoothly, other times there is quite a “click” and it skips. I know it is skipping because I’ve tried turning threads and it misses the thread track.
      I know the upper half nut has a partially knackered thread, but it has been like that since I got the lathe and it has worked previously.
      If anyone has any thoughts they’d be much appreciated.
      Steve355
        @steve355
        #572992
          There comes a time when the half-nuts need attention/renewing. But maybe there is something stopping or holding full engagement – an over-centre device, perhaps?
          #572996
          Ady1
            @ady1
            Its either too worn or it needs a good cleanout after being used for a while
            small particles can become compacted in the thread
            This is assuming it's 100% engaged when you throw the lever, the Drummond M has a smooth upper nut and a proper lower nut, so only the lower half engages but the proper support of the upper half is very important because of the leadscrew flexing when under load
            If they dont pinch-hold the worm securely the half nut thread pops out
            Edited By Ady1 on 25/11/2021 23:18:36
            #572997
            Clive Brown 1
              @clivebrown1
              In your picture, the pegs seem to be a rather loose fit in the cam slots. Could this clearance allow the half-nuts to jump out of engagment?
              #572998
              Steve355
                @steve355
                What is an over-centre device?
                I know the half nut needs sorting out, but I think I’ve done something else to it which is causing this specific problem. I’d love to get new half nuts but being 80 years old, replacements are a bit thin on the ground. The bottom and top half nuts are symmetrical in every way, and I’ve toyed with the idea of casting some new ones from the bottom one, but that’s a whole new project in itself, and something I know even less about than machining.I watched an interesting YouTube video of a chap in the US replacing lead screw threads on a Logan lathe, which was interesting but probably beyond my capabilities, particularly if my threading mechanism is out of action,
                I am pretty sure that the lower half nut is engaging slightly before the upper one. It may just be a question of lubrication and getting the gibs tightened correctly. Or it may be something to do with the lead screw – I’ve probably disturbed that recently when messing with the change gears.
                #572999
                Steve355
                  @steve355
                  Posted by Clive Brown 1 on 25/11/2021 23:11:46:
                  That’s interesting, I thought the same, but the threads they screw into are 3/16, they came like that, and it used to work, so I think that’s probably not the cause.
                  #573000
                  Steve355
                    @steve355
                    Posted by Ady1 on 25/11/2021 23:09:12:
                    I cleaned it all out thoroughly when I took it to bits.
                    but I think you are right about the misaligned engagement,
                    #573005
                    AJAX
                      @ajax
                      Posted by Steve355 on 25/11/2021 21:59:50:
                      Do you have any photos showing the half nut mechanism dismantled? I presume each half nut runs in a dovetail slide; if so, do those two grub screws allow any adjustment? Maybe slacken one half nut off to make engagement "loose" so the two half nuts don't try to compete together when you engage the lever. If the half nuts pivot rather than slide, maybe you could make an adjustable cam; that's the solution I tried when fixing a boxford.
                      #573009
                      DiogenesII
                        @diogenesii
                        ..a couple of observations, don't know whether of any value or not..
                        You suspect the bottom one engages first – many lathes of a similar pattern use shims between the apron and the saddle to ensure that the halfnuts are centrally-disposed to the leadscrew and can close on it together..
                        ..if you loosen-off the apron (beware of shims already in place) and then close the half-nuts onto the screw, does a gap appear between the saddle and top of apron?
                        ..before you do this, it might be worth checking the fit of the damaged half-nut with the leadscrew, just to make sure that there are no burrs causing it to 'ride' on the threads.. ..if it's been closed with enough force to bend the cam pins in some previous life, anything is possible, sometimes a little restoration of the thread form is necessary
                        #573011
                        Steve355
                          @steve355
                          Posted by DiogenesII on 26/11/2021 07:18:44:
                          That’s a really interesting idea. I will go and try it now. Ive had the apron off many times, and there were no shims, but I’ve always tightened it fully, if slightly loose, it may behave differently.
                          I’d be very interested in ideas to restore the thread that don’t involve needing a working half nut,
                          #573012
                          Steve355
                            @steve355
                            #573037
                            ega
                              @ega
                              Another test is to observe the leadscrew as the half nuts are fully closed: does it move up or down? If so, adjustment as suggested by DiogenesII is indicated.
                              #573042
                                Looking at the picture of the lever, it appears to be in the disengaged position.
                                Where are the pins in the engaged position?
                                They should not be bearing against the end of the slot.
                                Look for any burrs or bent pins, if you have not already replaced them.
                                If you did, (Judged by your thread on "Wonky Threads" ) are the threads concentric with the body of the studs?
                                Is there anything limiting the travel of the lever, or the studs driving the half nuts to prevent full engagement of both halves?
                                HTH
                                #573052
                                Steve355
                                  @steve355
                                  Posted by ega on 26/11/2021 11:23:13:
                                  It was moving up. So I have shimmed the apron with feeler gauges, and it seems (touch wood, pending further testing) to have cured the engagement problem. I’ve engaged it now maybe 30 times and hit the number on the thread dial indicator every time, no jumping or skipping.
                                  it it still stiff on disengagement, which is probably the same problem in reverse – one nut disengaging but the other not. I will look into that further.
                                  Thanks for the tip.
                                  #573054
                                  Steve355
                                    @steve355
                                    Posted by Howard Lewis on 26/11/2021 11:48:30:
                                    HTH
                                    Even though I seem to have made progress, there is still a problem with this lever in that the engagement position is too low (about 9 o’clock). Also, it has a system whereby a spring is I think designed to cause it to lock in the on or off positions. I will post some pics later. By the way, yes, I have fixed the pins, they are straight now 😎
                                    #573065
                                    Steve355
                                      @steve355
                                      Stupid question, but for these styles of lathes, is “down” usually engaged or disengaged for the half nut?
                                      thanks
                                      Steve
                                      #573066
                                        Maybe the bent pins are evidence of a previous owner having this problem and leaning on the lever to prevent skipping.
                                        Ideally, both half nuts will move symmetrically to engage simultaneously.
                                        Hopefully adjustment, somewhere, will solve the problem.
                                        #573067
                                          By the looks of the picture, rotating the lever anti clockwise (down ) would lower the top nut into engagement, whilst disengaging the lower one, which seems illogical.
                                          One thought.
                                          The pins seem to have lots of clearance in the slots.
                                          Is it possible that the pins should be 1/4" diameter, with a 3/16 thread on the end to increase the linear moment of the pins for given angular movement of the lever?
                                          #573070
                                          Martin Connelly
                                            @martinconnelly55370
                                            I would expect a spring to open the nuts when they were expected to disengage, you don't want then to stay engaged when disengagement is selected. The slots in the cam disk (for want of a better description) look far too big for the diameter of the pins, looks like poor design as it is so a spring pushing the pins against one surface (in this case the outer one) makes sense. As the slots do not look like they are the same width along their lengths this would increase the movement between open and closed and so adjustment of the disengaged position will change the angle of the lever upwards when engaged. The change in the curve of the outside surface of the slots also looks like an over-centre design where once the half nuts are engaged the movement of the pins is reduced or even reverses slightly.
                                            I would get some springs, adjust for full engagement at the point where the curve changes or just beyond it and see if there is full disengagement with the lever down.
                                            Martin C
                                            #573077
                                              A simple 1:1 lever to operate one of the halves would cure my complaint of a lack of logic.
                                              It could even be that the operating lever was replacement made by a previous owner, but not very well. Note the chatter marks on the chamfer.
                                              Certainly, having the pins a close fit in the slots will give increased travel to the half nuts, which may help. rather than trying to make a lever with narrower slots, larger pins, turned down for the thread may be the easier path to a cure…
                                              Removal of the Apron and a close examination of the half nuts and the operating mechanism would seem to be an the next item on the list of operations in the investigation.
                                              Careful reassembly, together with some checking of components ought to arrive, eventually, at a solution.
                                              Keep us posted on your findings!
                                              #573079
                                              old mart
                                                @oldmart
                                                My thoughts are that if the engagement mechanism is not backing off when under load, then the leadscrew is flexing downwards because of the shape of the worn nut threads. The Smart & Brown model A also uses a part section nut, but any flex in the leadscrew is stopped by a bronze slipper opposite the nut. I wonder if you could fit something on your Zyto?
                                                #573081
                                                  Where are you located?
                                                  It is possible that someone may be close enough to you to be able to come and help in your investigations, and repair / adjustment.
                                                  #573082
                                                  Steve355
                                                    @steve355
                                                    Thanks for the replies….
                                                    When I take it to bits again later that’s the 4th time today I’ll have taken it to bits!
                                                    I’ve watched several YouTube videos of people restoring Zyto lathes this afternoon. All of them have 3/16” pins, but all of the pins seem to fit, and the cam looks different. I think mine is either a replacement, or a previous owner has messed with it. None of them have springs.
                                                    I think Howard, your idea of turning down some thicker pins is the easiest thing to do there.
                                                    I still wonder how to fix remake half nut threads, but that might be a project for another day, presuming it works reliably once I’ve fixed the basic mechanism.
                                                    #573103
                                                    Martin Connelly
                                                      Quickest way to check if thicker pins work is to sleeve the ones you have on at the moment.
                                                      Martin C
