Changewheels for many lathes often increment by 5T, so at a wild guess, you could be looking for 35, 40, 45, 50, 55T.
An extra 20T or two may be useful, as possibly another 60T.
Arranged to give large enough ratio between chuck and Leeedscrew, you can get quite a low feed rate for turning. (You would be looking for something of the order of about 27 to 30:1 with a 8 tpi Leadscrew ).
The 63T should be useful if you want to cut Metric threads. It won't be absolutely accurate, but as Brian Wood's book shows, the errors can be small enough to be acceptable.
The Back Gear will allow the spindle to driven at a lower speed, (Possibly 6:1 slower? ) which can be very useful when screw cutting.
But don't forget to unlock the bull gear when using back gear, or everything will lock solid, at best; or do damage at worst.
