Mystery to me, Moore and Wright
Home Forums Beginners questions Mystery to me, Moore and Wright
Viewing 25 posts - 1 through 25 (of 26 total)
  • #541666
    Paul Barter
      @paulbarter66156
      Hello all, Back again to acess the knowledge
      These rods are marked with sizes, yet the tduplicate wo inch and one inch are consistently two thou over ie 1.002 and 2.002.The two micrometer heads have domed ends and are graduated for tenths.The rods have flat ends on truncated cones.Can anyone identify the name and use of these please?
      Paul Barter
        @paulbarter66156
        Help in identifying thuis set of tools please
        #541669
        Paul Barter
          @paulbarter66156
          Just to add to my post the two adjustable heads measure 3.625 when set to zero on the barrels were these for some very particular measuring process like go no go gauges?
          Thanks again for any suggestions Paul
          #541673
            Most probably an internal micrometer set, possibly with the heads in need of resetting to remove the 0.002 error.
            Which raises the question, before making ANY adjustments, of how accurate are the devices used to measure the overall length?
            Have they been checked against length standards or slip gauges, to confirm their accuracy?
            Do any, or all of the other extension rods show the same +0.002" ?
            If adjustment is required, the spanners with which to do it are there
            #541675
            Nick Hughes
              @nickhughes97026
              They are End Measuring Rods, used on a Jig Boring Machine.
              #541678
              Paul Barter
                @paulbarter66156
                Thanks to you both or the swift response, the rods are not adjustable and were measured with Mitutoyo micrometers set to to slip gauges so I am surprised at the consistency of the apparent error. also the rods marked 8 and 4 inch are also duplicated. A Jig boring machine is beyond my skill set, but how would these be used please Nick? is 3.5/8 of particular significance and why two?
                Thanks again to you both Paul
                #541684
                Nick Hughes
                  @nickhughes97026
                  Have a look from page 10 and on of this Pratt and Whitney brochure :- Pratt & Whitney Jig Borers Circular 513
                  If the link fails, PM me and I'll send you the PDF
                  Nick
                  Edited By Nick Hughes on 26/04/2021 16:01:40
                  #541685
                  Paul Barter
                    @paulbarter66156
                    Thank you very much Nick, the link worked perfectly and I shall enjoy reading all of it. The penny has dropped! I doubt that I will ever use these as intended but they were too interesting to be left at the car boot! In any event I now have a set of standards up to 12Inches
                    Thanks Paul
                    #541687
                    Clive Foster
                      @clivefoster55965
                      As Nick says these are used in jig borers to accurately set distances. Often toolroom class milling machines had a trough on the front of the table to carry them when doing accurate work. Even Bridgeports had an accessory to enable their use.
                      The adjustable heads are nominal 3.625" long. They should be set to read 3.625" on zero by the usual method of turning the micrometer sleeve. However some firms preferred to leave the sleeve in a fixed poistion and note the error. My set, obtained for a specific maybe job but never used, has calibration labels for the two heads. One says 3.6258 an one 3.6250. If I ever use them I shall sort that so both are calibrated to 3.6250
                      The length bars should be accurate to ± 0.00005" at standard temperature. That equates to less than 0.0001 error band. No idea why you are measuring one or 2 thou over. That said out in the real world you'd expect regular calibration with last time details to be in the box
                      These would normally be used with a tenths thou indicator. See the picture half way down this page :-
                      **LINK** , http://www.lathes.co.uk/bridgeport/page3.html for the Bridgeport accessory set up.
                      PS Nick sent a very interesting link whilst I was typing making the above post pretty much redundant! I've grabbed the P&W information from Nicks link too.
                      Edited By Clive Foster on 26/04/2021 16:18:49
                      #541709
                        Posted by Nick Hughes on 26/04/2021 15:52:58:
                        Clever use of the dial indicator :
                        bernard towers
                          @bernardtowers37738
                          Dropped on my doorstep this morning, its brand new but actual M&W information is scant to say the least. Cant think of a use for it in the average model makers workshop can youIMG_3447
                          #713928
                          Speedy Builder5
                            @speedybuilder5
                            We called them “stick mikes” and had sets measuring 5 foot long. Used them for making the jigs of the TSR2 forward fuselage. Hell of a problem with trying to make accurate measurements in “fan heated” open workshops!
                            #713938
                              Family resemblance to my M&W Bore Micrometer.
                              #713942
                              Diogenes
                                @diogenes
                                ..you could set stops on a mill table or lathe saddle with them..
                                ..might come in handy when the price of electricity makes you think twice about turning the DRO on..
                                Just realised my redundancy – that’s what happens when you arrive at the bottom of a thread and scroll up – apologies.
                                #713946
                                DC31k
                                  @dc31k
                                  The original post in this thread notes that two of the length standards appear to be oversize by 0.002″. Could you check your one and see if the mystery from 2021 could be advanced.
                                  #713981
                                  Chris Crew
                                    @chriscrew66644
                                    This has got me thinking. I acquired a M&W bore micrometer in box of ‘odds and sods’ years ago at the British Timken works closure auction in Northampton. I think it extends to about 18″, possibly, and has been lying a tool cupboard since as I have had no practical use for it. Now having read the P&W brochure and seen how a jig borer is used, I am thinking could suitable cradles and stops be made and fitted to the milling machine to lay the bore micrometer in? Obviously, this would not approach the accuracy of a jig borer but it may just be a quick way of indexing holes and edges etc. rather than just relying on marking out lines. Anyway, just a brain fart at the moment until I get down to the workshop in the morning and have another think about it.
                                    #714035
                                    Chris Crew
                                      @chriscrew66644
                                      Yes, it was just a brain fart. Having looked at the Mill there would be no real practical way of using the bore gauge to index. A DRO, which I do not have fitted, would be a far better proposition.
                                      CEJ Bore Gauge on Mill 1CEJ Bore Gauge on Mill 2CEJ Bore Gauge
                                      #714036
                                      Chris Crew
                                        @chriscrew66644
                                        BTW, I have just noticed it’s Johanssen bore gauge, not M&W as I previously thought. It came in a box full of bits and pieces and I seem to recall bidding £2 for the lot.
                                        #714037
                                        bernard towers
                                          @bernardtowers37738
                                          DC31k, The red one is on the money at 3.625″ and the green one is 3.6255. Does this help?
                                          #714040
                                          bernard towers
                                            @bernardtowers37738
                                            DC31k, The red one is on the money at 3.625″ and the green one is 3.6255. Does this help?. The 1 inch pieces measure 0.99976″ and 0.9999″ and the 2 inch ones are 1.995″ and 1.996″. This all done with non certified measuring gear!.
                                            #714043
                                              Would you like to double your money, on just that item, Chris ?
                                              Mark Rand
                                                @markrand96270
                                                Red and green are Go/no-go calibrations.
                                                #714411
                                                JohnF
                                                  @johnf59703
                                                  A wee bit late but foe interest here’s a copy of the M & W cataloge page from my archives —
                                                  56FAD44C-1275-4D61-B340-BF8F2E6CA4F7_1_201_aF38E43FC-7894-477B-AB96-5D5AEB90FA68
                                                  #714429
                                                  bernard towers
                                                    @bernardtowers37738
                                                    Thanks for that John I now know that I hve set 788/C for all the good that it will do me as they seem to be a little used tool any more, so its under the bench for now!
                                                    #714532
                                                    Mark Rand
                                                      @markrand96270
                                                      Same here:-
                                                      20240215_174041
                                                      I was also wrong in my assumption about go/no-go calibrations 🙂 . They were an impulse buy a number of years ago and help to stop the other little used metrology tools getting lonely.
