You don't need to align the steady, just make sure it sits right
It's the workpiece that needs aligning, use a dti
can take a while, a dead centre in the tailstock helps a lot, then remove it for final tweaks
edit you can use other systems like the cutting tool touching but if you want good accuracy you must get a dti system setup
GL
Edited By Ady1 on 04/02/2021 11:32:22
