Method I've always used. Clean mating surfaces, heat parts and using good old 60/40 Multicore, lightly coat surfaces. While still hot, wipe solder off with a piece of damp kitchen towel ensuring faces are fully coated but no thickness of excess solder. Clamp pieces together and reheat. Shouldn't be enough solder to squeeze out, If you've wrung slips together you get the idea.
Clamps? Vice with a couple of bits of wood to insulate heat drain, Heating media? Small blowlamp.
Regards Ian.
Edited By Circlip on 07/11/2020 11:59:06
