I doubt it is a No 5 unless it's been made with seriously undersize connections as that should use flanged connections with 3/8" clear inlet and 1/2" outlet.
For the current No7A the threads would be 1/4x32ME which would have 5.6mm tapping size. Not sure if the old original No7 had different maybe 1/4" Whit. In any cast the builder may not have used the specified thread and Stuarts have always used a coarser one than most other makes of steam fittings use so only their fittings will fit. Stuarts list inlet pipe for the 7A as 3/16" and 1/4" on the exhaust
Edited By JasonB on 30/10/2020 07:23:15
