Posted by Mick B1 on 07/08/2020 18:29:57:
Matter of personal choice. You'll still have to make sure your backlash is taken up in the right direction to resist the cutting thrust, but it'll be easier to count off slide movements with less mental arithmetic, or risk of mechanical disturbance zeroing dials..
Myself, I prefer to use basic methods and dial-off the movements. It keeps me aware of how well or otherwise my head's working.
Whether the extra money's worth spending also depends on what tooling you've already got, how much you need additional stuff, and how much uncommitted cash you have.
+1
Fitting a DRO to a milling machine is a no-brainer. Multiple dial turns in 3-axes and don't forget to compensate for backlash! DRO is extremely helpful.
Less so on a lathe. They only have two axes, and one of the dials doesn't move far. Backlash compensation is much easier because most lathe work concentrates on one axis at a time. So I drive my lathe differently to my mill:, I calculate how much metal must be removed, cut close to that value on the dial, and then finish off with a micrometer.
If someone gave me a DRO I'd cheerfully fit it to my lathe, but I'm not moved to buy one. As always the value of a tool depends on the individual. Keith mentions novice confidence as a benefit, and Chris with 57 years experience recommends DRO for speed and ease of use. They're both right, but the novice stage doesn't last long, and I suspect most amateur turners work slowly compared with Chris. Well I'm sure I do! In my workshop, a lathe DRO wouldn't save much time because I'm rarely in a hurry.
Of course if money is no object, buy one. But if money is short it could be better spent on something more useful. Knurling, Ball-turner, QCTP, Drill Chucks, Tap and Die fittings, micrometers, squares, calipers. Collet chuck with collet set. Carbide inserts, HSS and Grinder, Oil can, DTI and stand, spanners. The list is endless…
