Posted by James Hall 3 on 02/08/2020 14:50:52:
As I've just blown my life-savings on this I'm sure that you'll understand my desire not to start using it if wear-causing cr*p is hanging around inside the mechanisms.
I do understand! We've all been there, done that and got the tee-shirt. Taking mum's kitchen clock apart to see how it works is a rite of passage. Unfortunately most of those clocks never worked again.
How much work do you expect to do on your lathe? Modern bearings are sealed, and the banjo, gearbox, lead-screw are robust affairs on most hobby machines of SC4 size, which are usually lightly loaded. It's not like a car where the mechanism gets hot and runs for hours on end. What matters more to machine tools is alignment and adjustment. If the saddle traverses smoothly and all the controls work no harm whatever in spending a month or two using the machine. I spend far more time planning and setting up than actually cutting. Unless you're planning a lot of hard work it's unlikely a little grot inside will do much damage, whereas cutting tapers rather than parallel is a major problem.
In the early stages easy to cause grief with semi-skilled dismantling. You're more likely to break it than a bit of carp, and the guarantee doesn't cover your mistakes. If it ain't bust don't fix it. And if you take her apart and then ask about cutting problems on the forum later, we'll have to add your doings to the list of potential causes. A new lathe should do X,Y & Z, but all bets are off if it's been dismantled.
I'm not saying never take it apart, just good tactics to slow down and reconnoitre first. After you've got used to the machine much easier to recognise issues and make improvements. Don't rush it.
I changed the oil in my lathe's gearbox 2 years late. It was still clean. Although I use it at least two or three times a week, it rarely works hard for hours on end. Lightly loaded machines will survive a long time in imperfect conditions. Heavily loaded machines need plenty of TLC, but I'm expecting your SC4 to be a Gentleman's Accessory, not a Grafter's Three-shift Metal Muncher with production targets to meet.
