Gas burner
Gas burner
Home Forums Locomotives Gas burner
  • #1019
    clive swinney
      @cliveswinney28133
      clive swinney
        @cliveswinney28133
        I have nearly completed my first locomotive, it is ERIC from Steam trains in your garden. The gas burner is a10mm brass tube with fine slots cut into it and one end sealed. This fits into a 19mm tube running lengthwise through the boiler. The burner lights well outside the boiler, but will not light in place, the flame coming out of the end of the boiler tube in the smokebox. Does anyone have any experienceof this or suggestions. Thanks Clive
        Edited By clive swinney on 20/06/2011 15:00:56
        #70591
        David Clark 13
          @davidclark13
          Hi Clive
          I would join the following 2 email groups if not already a member.
          The first one, you have to request to join.
          The second one just join.
          They are both full of 16mm modellers, many who are building Erics.
          regards David
          Beware the list owner, stray off topic at your own risk.
          <Steammodelloco16mm.yahoogroups.com>
          <16mmngm@yahoogroups.com>
          #70606
          clive swinney
            @cliveswinney28133
            Thanks for the information David, I will try these groups.
            #70608
            Richard Parsons
              @richardparsons61721
              It looks as if you are getting No secondary air into the 19mm tube or no draft through it. A short bit of pipe in the chimney with a little bit of pipe blowing up it with a foot pump. There is a sketch of this thing in the book of the Titch by LBSC. It induces a draft through the boiler.
              Rdgs Dick
              #70611
              Jeff Dayman
                @jeffdayman43397
                Hi Clive,
                Sounds like the gas pressure may be too high. Can you reduce it some way?
                With small gas fired models I have built, the gas is turned on low as possible, let a few seconds go by and then I light the fire at the chimney or at the open smokebox door. The gas flares with a ‘woosh’ or ‘whump’ and then the flame front travels right back to the burner and settles down over it. After a few seconds the smokebox door is shut if open. Again gas pressure has to be low as possible for lighting up, in my experience.
                Note about induced draft and exhaust blowers with gas models – I personally have not had luck with either, they tend to lift the fire off the burner and when that happens the fire can go out or at least become unstable for good steaming. Your mileage (and others’ mileage) may vary…..
                JD
                #70638
                doubletop
                  @doubletop
                  I have tried exactly what you have described , even to the tube dimensions being the same, and had the same results. As Richard suggests its a secondary air problem and not easy to resolve. I came to the conclusion that poker burners are only any good in any open environment say for a hedgehog or basic water tube boiler.
                  See link below
                  I think I then moved on to a blow torch type burner pointing down the 19mm tube and the poker became a nice ornament.
                  Pete
                  #70658
                  Steambuff
                    @steambuff
                    Clive,
                    I have poker burners in all my 16mm loco’s, and I will have in the Eric I am building.
                    All Roundhouse, Accucraft etc 16mm loco’s use poker burner’s, so therem is not a long with them, I admit that they can be a pain to get working correctly.
                    Have you joined the steammodelloco16mm yahoo group yet? They should be able to help. (Brian Wilson the books author is a member and he often offers help.)
                    Dave Bond
                      @davebond87219
                      As a slight side topic are gas fired boilers the same as a coal boiler? So for example could a coal boiler be retrofitted with a ceramic or equivilent burner?
                      If this is the case are there size limitations for using gas, would it be practical to fire a 5″ steam loco on propane?
                      I ask this not because I would move away from the sight and smell of coal but just as an interesting thought as I see Maxitrack have gas fired locos and I wonder if there are differences between the two boiler types.
                      #72102
                      Steambuff
                        @steambuff
                        Yes and No
                        In general a Coal fired Boiler/Firebox could be converted to fire from a Gas Ceramic burner. (In the 16mm NG world – TME do this, they can supply the 3 firing options Coal. Gas or Meths or all 3)
                        In the 16mm NG world a boiler designed for Internal Gas firing cannot be used for Meths or Coal, firstly it has no firebox …. the usual design is a single tube running through the lower part of the boiler, into which a ‘poker’ gas burner is inserted.
                        Dave Bond
                          @davebond87219
                          Ok the thought I had was a multi tube fireboxed boiler that would normally accept coal as a fuel. So I imagine a ceramic burner as the heated ceramic would resemble a fire bed as a coal substitute? Also it would be a more even heat ??? I am only guessing here hence exploring this idea on the forum.
                          #72141
                          doubletop
                            @doubletop
                            Posted by Dave Bond on 19/07/2011 15:52:15:
                            I run my Rob Roy (3/.5″) on propane using a ceramic burner based on a commercial version that I believe came from Bruce Engineering. One of our club members runs his Manor (5″) on gas . And a guy in Belgium I’ve been communicating with has converted an OSLiveSteam Rocket (5″) to gas. If you trawl through the American sites you’ll find a lot of them running 7.5″ locos on gas. These are a mix of ceramic and jet type burners. The only change to the boiler is a stainless ‘arch’ which restricts the direct draw down the flues and stops the flame being drawn off the burner. Check out link here.
                            Pete
                            Edited By Doubletop on 20/07/2011 07:59:11
                            #72142
                            doubletop
                              @doubletop
                              An example of what I’ve called ‘jet’ type burners
                              Pete
                              #72143
                              Dave Bond
                                @davebond87219
                                As gas burns hotter than coal is there any issues with the proximity to boiler sides, would deflectors be used?
                                In your above comment I take it the deflector described would be like a brick arck in a full sized loco?
                                #72168
                                doubletop
                                  @doubletop
                                  I would suggest that it doesn’t burn that much hotter than coal, it is more consistent over a larger area rather than hot spots that I’d guess coal is prone to. You have way more control and can shut down immediately which you cant to with coal.
                                  I’ve secured my ceramic with Permatex hi temp RTV (for car gaskets) and its holding up well. It does not burn as a fiercely as the gas torch you’d use to make the boiler.
                                  Take a look at the link I’ve posted for pics of the stainless ‘arch’. Arch what the guys call it but its probably only remotely similar to the real thing.
                                  #72170
                                  Ompa Ompa
                                    @ompaompa11814
                                    Just to add my twopennyworth…..I currently run a 5″ gauge ‘Brit’ (Lookalike) on Propane. I use a total of six ‘Marty Type’ burners in a configuration that gives me the chance to run either two, four or six at one time. On full six I can maintain around the 90 psi mark. One issue I have is with the cost of gas, my choice to use it, so can’t complain. I am still experimenting with additional items such as an arch, ceramic infills and some others, all to improve heat retention. I do use a small amount of steam to create a permanent draught at standstill with natural exhaust when running doing the same job, just as with coal firing.
                                    #72224
                                    doubletop
                                      @doubletop
                                      On the subject of gas. In NZ the only thing readily available is LPG which is a propane/butane mix. The trouble with this is the propane burns off first leaving the butane so the calorific value drops dramatically when the bottle gets about 1/3 full. If you get the bottle refilled at a petrol station they just top it up so now youv’e got less propane. And so that goes on until you either burn off all the butane by some other means than running your loco. Fortunately our local BOC purge the bottles before a refill and a fill of a 3kg bottle is about $12 or 6 quid so you are only chucking away about a pound or two each time.
                                      I did ask BOC about pure propane but when they started talking about couriering the empty bottle up to their lab in Auckland it got obvious than it would be more than 6 quid a fill.
                                      Pete
                                      Edited By Doubletop on 21/07/2011 09:40:44
