Cutting a large internal hole
Home Forums Beginners questions Cutting a large internal hole
  • #467025
    Gavin Mclean
      @gavinmclean68552
      Hi guys – son is using a warco 240 lathe to make motorcycle fork nut caps – is there a quicker way to make a large internal rather than using the boring tool and taking 0.3 mm cuts from the centre – not sure how else to describe this – one is a 47 mm internal and the other a 30mm wide and around 10mm deep
      Gavin Mclean
        @gavinmclean68552
        #467028
        old Al
          @oldal
          drill to the biggest drill you have, then bore with a boring tool. Minimum overhang, you should be able to take bigger cuts than 0.3
          #467031
            You could try grinding up a HSS toolbit (say 6 – 8 mm sq ) to make a knife tool.
            Mount it in the toolpost along the axis of the lathe, with 12 -15 mm protrusion
            (Check that it will not hit the vice jaws! )
            Having made a central hole with a drill, or drills at least as big as the toolbit proceed to take a series of cuts along the axis of the lathe.
            The tool should be be more rigid than a long boring bar, and so should withstand deeper cuts, say 0.5 – 0.6 mm ,to rough out the bore. The boring tool can then be used to finish the bore, and to face the innner end.
            #467044
            Pete.
              @pete-2
              Good quality starrett holes saws can be bought for £5-£8ish, just make a hole 5mm less than the finished size, then finish with a boring bar.
              #467051
              Bob Rodgerson
                @bobrodgerson97362
                Gavin, you should be able to take larger cuts than o.3mm as already stated but to be honest that is not a great deal of material to open out to.
                Patience is a virtue.
                #467061
                  For those suggesting holesaws or warning about boring into the chuck jaws I think these caps have a blind bore that fits over the nut to cover it rather than a through hole.
                  As said you should be able to take more than 0.3mm cuts, set the boring bar, even a long one so it only projects a few mm more than the 10mm depth of recess from the tolpost..
                  #467081
                  John Haine
                    @johnhaine32865
                    I'm trying to work out what other kind of hole there is…
                    #467092
                    old mart
                      @oldmart
                      That's not a big hole, and in aluminium most likely, unless its for a Harley. 0.5 cuts should be fine unless you are using a tiny boring bar.
                      #467193
                      ega
                        @ega
                        Posted by John Haine on 25/04/2020 20:31:00:
                        I imagine your tongue is in your cheek; however, I took the OP to mean blind hole.
                        #467276
                        Gavin Mclean
                          @gavinmclean68552
